EF Chinn Yak
#51
RE: EF Chinn Yak
Likely, the Ultimate 70 will do the job, but with a little less "left over".
My Chinn Yakk has equal odds at a Saito 72 or 82. It depends on which other plane I crash first, to free up the engine.
#52
RE: EF Chinn Yak
Hi All,
Who know - what company (except EF) also distribute Chinn Yak-55?
Is anybody try to combo s-63FZ& Yak? Is the anrtivibration mount need to use?
Thanks.
Thanks.
#54
RE: EF Chinn Yak
Freestyle-rc are the distributors in Europe and they do carry the entire EF line up, here is their website www.freestyle-rc.com
#56
FL
RE: EF Chinn Yak
ORIGINAL: garygee
Thanks tailtwister for the info.......why do you only use one washer instead of two ?
#57
My Feedback: (9)
RI
RE: EF Chinn Yak
OK boys im in on the thrust offset plates. Now can someone tell me where to buy them I cannot find them on OMP's site. Also just ordered some graphics from B and E Graphics to dress up my russian scheme alittle more........will post pics when complete.
#58
RE: EF Chinn Yak
I do one washer, just because it feels better for me. I like the thrust line a little closer to center than most folks. I'm in the minority there.
I don't see the plates on the OMP site either. Maybe just call John and see if they still have them or not. Also, Paul Swany used to sell them.
#59
FL
RE: EF Chinn Yak
#61
VA
RE: EF Chinn Yak
Ok, I know this is going to stupidly overpowered, but I stuck my saito 91 on my yak. Fully built and with no fuel I came in at 4 lbs. 11 oz. I stuck everything I could on the opposite side of the engine to lateral balance it. The engine is mounted pretty far back. When I went to balance CG I started a the beginning 5'' and still had to put the battery in to almost the leading edge of the wing. So I ended up balancing at 5 1/4. I also made it so I can move my battery back when needed. Also I didn't like the hardware. I broke 2 rods trying to screw on the ball swivels. I ended up using some other stuff I had laying around from another kit.
#64
My Feedback: (9)
RI
RE: EF Chinn Yak
tailtwister got my offset plate in...what leading edge do I use the fat side or the smaller tappered edge. If I use the fat side it way over the size of two washers, should I cut it in half and start from there ?
#65
FL
RE: EF Chinn Yak
The thrust plate is 2 degrees. Cut it about 1/8" bigger than the engine rails put it under the engine rails. It doesn't matter if you use the thick part or the thin area - It's still 2 degrees.
#66
RE: EF Chinn Yak
Scott is correct. 2=2 no matter what. But, I'd use the thinner part to keep the engine as centered as possible. It won't make a big difference, but that's my $0.02 for the record.
#68
PA
RE: EF Chinn Yak
Hey all wassup i just ordered a chinn yak for asaito 56 swingina 13 / 4 w .on 30% it wont hahe the snot of an 82 but it flew a 4- 3/ pound tribute ok on 20% whatha think
and i got a alum tubo muffler for it
if i can keep at 4 pounds should work any one have a setup close to this?
#69
AK
RE: EF Chinn Yak
That's a pretty small engine for this plane. I think it would probably do OK but I'm concerned that it will require a bunch of weight to be added to the nose for balance and negate the weight savings making her pretty sluggish.
#74
VA
RE: EF Chinn Yak
ORIGINAL: moogyman
i do have a 125 layin around hmmm
