Sledge 540 Best Fuel Tank?
Its seem's that I'm getting bubbles in my fuel causing my ST 51 to dead stick, and before I install the YS 63 I want the fuel system right.
I forgot whats in it now, it was a 6 or 8 oz dubro in the wing right side/engine side. and I had to remove a servo to get to it before and it was still a very tight fit could not get foam all around it soo tight. The last time I replaced the tubing and made sure everything was tight. But I still get some bubbles.
I'm now going to replace the tank and fuel tubing with brand new.
Should I get a smaller tank so foam will fit/go around?
What do you think is the best tank?and size?, Esp. considering I'm eventually going to install the YS 63 and that I want the tank in the wing on this plane?
Many Thanks, Dennis
Many Thanks, Dennis
My Feedback: (12)
Tank..
I have the 8oz Dubro mounted in there. I am running a HS-81 throttle servo mounted in the center rib with just the servo arm hanging out in the bay with the tank.
I don't have a lot of foam around it..some in front, and some on either side of the spar top and bottom. I built a little dam behind the tank to keep it from moving back. I can hear the wing creaking when I let the pressure off the tank so I know it has to be swelling up and hitting wood.
I don't get any bubbles, and this tank isn't what I would call well padded, but I think the lower revs of the 4-stroke makes for less bubbles. I can fly with perfect performance all the way to the bottom of the tank. Which brings up the next point..
You will hate it with a 6oz tank on a YS 63. I have to be very careful to keep from running out of fuel. Just about the time I really get to going good I have to land. I've never had a dead stick, but I've landed on fumes.
Thanks, Chuck, I was wondering myself if different vibrations of the 4 stroke might not make bubbles, but then again I remember some saying 4 strokes have more vibration.
I guess the different frequency vibration could have a different effect/ no or more bubbles.
Can other's chime in on this?
Mabey I can just go install the YS and see what happens?
Thanks, Dennis
Thanks, Dennis
IN
Dennis, I run the sullivan 8oz rectangle tank turned on its side so it fits. I never have put foam around any of my tanks on a profile plane and never had problems. I run the MVVS 49 though, and the YS63 may need a hayes tank to stand the pressure. Best of luck, Jeff W.
