Su-do-khoi 60 tank?
My Feedback: (10)
MT
Su-do-khoi 60 tank?
I recently won a raffle at our local club for a used Su-do-khoi 60. I can't figure out how to mount the fuel tank.[>:] The online instructions say: "Install the fuel tank with rubber bands."[sm=71_71.gif] I have never seen a tank mounted with rubber bands. Does anyone have this plane and could show me a picture of how their tank is mounted? Or could someone offer some tips on how to mount a tank with rubber bands?
Thanks in advance.[8D]
My Feedback: (14)
RE: Su-do-khoi 60 tank?
The second pic....where you're holding the tank to the fuse.........that's it!! Make sure you put a thick piece of foam under the tank before you mount it, then attach with some rubber bands..from the top hook to the bottom hook!! You may even want to put a couple bands criss-crossed.
EASY AS PIE!!!!
EASY AS PIE!!!!
My Feedback: (10)
MT
ORIGINAL: daveopam
I use fuel tubing. Tie a knot in each end of it and stretch it to the hook. Rubber bands work well but the fuel will eat them up after a while. Be sure and put a little foam under it also.
David
David
That's a neat idea!
