Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
katana v2 46
Old 03-12-2009 | 03:37 AM
rhk
Default katana v2 46
Has any one flying this plane have dead stick issues. Current set up is with an os 46 ax, with supplied tank. The engine runs fine on the ground, even when holding it upright, on the sides and with a nose down attitude. However when flying at 50% - 75% throttle, the engine cuts off on the down turn of the loop. Tried running the engine richer, but results are the same. The plane hovers fine. Have 1.5 inches of foam between the tank and fuselage , and could not appreciate " bubbling in the tank.
Had similar issues with the Kat v2 70 and mvvs 91 engine. Thought that I would have better results with an os !
Would appreciate all suggestions.
Old 03-12-2009 | 09:25 AM
ThumbSkull's Avatar
My Feedback: (57)
Default RE: katana v2 46
Sure sounds like fuel foaming issues. Try a sintered bronze fuel pickup in the tank like this one. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD741
Really does help with that issue.
Old 03-12-2009 | 11:10 PM
rhk
Tried that already. Have replaced the plastic ties with rubberbands and have now wrapped the tank in foam. Will check again this weekend.
Old 03-13-2009 | 12:04 AM
ThumbSkull's Avatar
My Feedback: (57)
The tank needs to be secure but not too tight that it can't move. Actually so the tank can remain still while the airframe vibrates around it.
Best of luck.
Old 04-06-2009 | 07:43 AM
rhk
Tried flying with a uniflow system in the tank, only to deadstick, once again, exiting a loop !
Was flying so far with the baffle removed from the muffler to get more rpm. Replaced the baffle and voila, the problem disappeared.
Wonder what the reason is.
Old 04-07-2009 | 09:32 AM
craigteffe's Avatar
My Feedback: (24)
not enough preasure in the tank to help push the fuel out when in the high G condition.
Old 04-13-2009 | 10:34 AM
wahoo's Avatar
My Feedback: (59)
Hey rhk,
If you want increased performance out of your engine without sacraficing reliability there's a couple options for you to try.
One would be purchasing a Tower Hobbies .46 replacement muffler.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJB16&P=Z
And the second would be to build a mousse can muffler.
http://webpages.charter.net/rcfu/ConstGuide/MCM.html
