Morris Rossi Exhaut On Os 46 Fx ?????
My Feedback: (58)
Is anybody experienced this combo:
ROSSI exhaust pipe modified by Morris on a OS 46 FX ?
What advantage to expect for fun fly ?
thanks
phil
thanks
phil
NC
using it now
I have used this conversion on several planes with much success. I have found the midrange to be alot better and with an increase in total rpms as well. this setup or the tower muffler is a good stepup from the stock muffler. Hope it helps, BAD ANDY
Good for an extra 1000-2000 rpm depending on prop. Only drawback is that it is LOUD so check if you have noise restrictions.
Good luck!
Good luck!
My Feedback: (16)
TX
f2racer is right, it is a screamer !!!But you can expect a big increase in power. I had it on my OS50sx, and got a little over 2000 rpm increse with a APC 12x4 prop. Everybody will turn heads and give you a nasty look when you rev it up. LOL
