MoJo Hardware???
I am working on my MoJo build and need to figure out which hardware to fget for it.
What stuff you guys using? Control horns: Tail wheel: Anything else? I plan on making my own control rods. |
RE: MoJo Hardware???
Ken,
Standard 40 size stuff will work just fine. Dubro 40 size tail wheel, 6 or 8 oz. hayes tank. Engine of choice. Wheel collars for the wire gear and wheels of course:D. You'll love this bird......have fun and post up any questions and many will be glad to help you out. J. |
1 Attachment(s)
ORIGINAL: Ken Bryant I am working on my MoJo build and need to figure out which hardware to fget for it. What stuff you guys using? Control horns: Tail wheel: Anything else? I plan on making my own control rods. Dubro HD Control horns Dubro Super Strength Long Servo Arms Dubro HD Ball Links (4-40) for the servo side. Dubro HD Clevises (with the locking pin) for the control horn side. Homemade CF pushrods. I cut 2" pieces of 4-40 rod & JB Weld them to each end of a properly cut roud CF rod (I forget the diameter, but the 4-40 rod just slides inside it) For the throttle, I use a dubro flex cable & just solder the ends solid & use dubro e/z connectors to attach on each end. For the tailwheel, i use a sullivan. (the small one) Good luck, it's an awesome 3D plane that's tough as nails. I've had some vicious cartwheel landings & lots of doinks out of a hover & it's still going strong. In fact, these pictures were taken after it had crashed 3 times that day. ;) |
| All times are GMT -8. The time now is 12:27 AM. |
