RCU Forums
-   Profile and Fun Flying Planes (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/)
-   -   fun51 engine (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/6148098-fun51-engine.html)
bryon 07-23-2007 09:32 PM
fun51 engine
im building a fun 51 dont know what engine i should it on as far as power and weight i have a 40& 46 la and a super tger 45 but didnt know witch would be best ?
rtn9105 07-23-2007 09:59 PM
RE: fun51 engine
I flew the fun 51 with a ST45 and it performed very well.
paulsen 07-24-2007 05:20 AM
RE: fun51 engine
I would go with the LA40 since the plane is so light and get longer runtimes then the LA46. The Super Tiger is pretty heavy (about 6oz heavier! ) especially for a plane this size.
flightcrazed 07-24-2007 07:56 AM
RE: fun51 engine
I had a TT46 on mine, it would have hovered if the rudder and elevator were a little bigger.. If I were building another I would extend them both about an inch.. If your not looking for it to hover, built as is it'll KE all day, I'd put the 40 on it. If you modify the rudder and elevator, put the 46 on it. Just my $.02.
PA BEN 07-24-2007 07:16 PM
RE: fun51 engine
A size 40 would be fine. I put a evolution 46 on mine way over powered.
http://i154.photobucket.com/albums/s...7/PICT3585.jpg
http://i154.photobucket.com/albums/s...7/PICT3588.jpg
troposcuba 07-25-2007 01:30 AM
RE: fun51 engine
got the ST .45 on mine. the plane and engine were given to me free. the guy was sick of fixing where the landing gear mounts to the fuse (and had ripped itself clean a couple times) i think i got that prob whooped. the engine ran horribly when i got it. i tore it down (thinking it was junk) and found no damage really. just a ton of varnish. cleaned it, lubed it re-assembled and it runs much better. not what i would call perfect but at least acceptable. runs great in the mid to high rpm. and the plane flies awesome. almost unlimited vertical. it stops going up eventually, but i get bored going straight up and have to do something before it tops out anyway.
check out the crazy repairs i did to reinforce that weak point where the landing gear attaches. I think it will take on anything now. check out the re-construction thread [link=http://www.rcuniverse.com/forum/m_6091745/tm.htm]here[/link]
bryon 07-27-2007 01:41 PM
RE: fun51 engine
thanks guys, info sure helped now time to start wings
bryon 07-27-2007 01:43 PM
RE: fun51 engine
nice lookin 51 pa ben
ramcharger 07-29-2007 02:50 PM
RE: fun51 engine
:eek:I just finished a Fun51. It has a ST 40 however I used the small ST muffler. The larger
ST muffler extends over the landing gear and that could be a problem on a ploop
landing. It has about 10 or 15 flights and I like it a lot. I'm concerned about the
vibration in the nose. I use a balanced 11x4 MAS prop. Its a great flyer.
ddrake24 08-01-2007 07:00 AM
RE: fun51 engine
1 Attachment(s)
I put an OS 46 in the one I built for my son. It performs great.
MikeMc 08-14-2007 05:47 PM
RE: fun51 engine
1 Attachment(s)
I had the LA40 on mine and it was more than enough power. Good times.
65010 03-07-2008 04:33 AM
RE: fun51 engine
1 Attachment(s)
I have put an OS 55 AX on mine...
frenchie79 03-07-2008 05:32 PM
RE: fun51 engine
1 Attachment(s)
DITTO on the AX55-opps, this ain't a fun fly. Same thing though. 46AX with a 12.25x3.75 prop so nice-55AX with the same only better.
GhostRider32 06-04-2009 11:41 PM
RE: fun51 engine
Question guys, when you covered your Fun 51, did you cover the fuse, ailerons, tail parts individually? I've got everything but the fuse and wing covered and was wondering if it would be better to cover the fuse and then slide the wing in, glue the wing and then finish covering the wing?
jimmyjames213 06-05-2009 11:23 PM
RE: fun51 engine
im building one, covering everthing before i assemble. i think i will have a problem w/ the servo heads hitting the fues as i slide it over (servo's installed before covering.
im putting a old os 40 fp in the plane. hopefully it will have enough power
jimmyjames213 06-22-2009 01:07 AM
RE: fun51 engine
just a update for anyone that may read this,
 i put a gms.47 in mine i didnt like it. it was to nose heavy even w/ the engine as far back as possible and the plane would not harrier/float what so ever, it just wanted to stall when i slowed it down even w/ flaperon at 15 degrees.
w/ the fp i need 1 oz up front and the engine as far forward as possible to balance. it flies very well both w/ and w/o flaperons, you can slow it waayyyyy down which is really cool.
i think the os 46 la would be perfect, the 40fp (similer to 40 la) can almost hover on a apc 11x5 (going to try 12.25x3.75), and i bet you wouldnt need the oz up front to balance
Constrictor 06-22-2009 01:08 PM
RE: fun51 engine
Ys .63 oughtta be perfect.
daven 07-20-2009 09:18 AM
RE: fun51 engine
I started with a Webra 40 black head and it wasn't enough. Went to the OS .46fx which was plenty, but needed a bunch of tail weight to get it to tumble how i liked. It did an awesome climbing inverted spin. With its short moments, it tumbles pretty good and knife edge loops are a breeze, it just doesn't hove or harrier all that well. Fun plane, got lots of flights on mine.
rlevy 07-31-2009 07:10 AM
RE: fun51 engine
I flew a Fun 51 with a Norvel 40 bb engine. Plenty of Power.
FlyFanatic 09-05-2009 12:35 AM
RE: fun51 engine
What do you guys think about a OS 56 fs-a ?
jimmyjames213 09-07-2009 08:40 PM
RE: fun51 engine
ORIGINAL: FlyFanatic
it should be fine, ground clearence should be ok im running a 12x4 or 12.25x3.75 and have enought clearence.
FlyFanatic 09-07-2009 10:05 PM
RE: fun51 engine
sounds good, I will find out shortly...
