Knife Pull-Pull Tubes Installation
I am in the process of build my new Knife kit and I am at the point where I need to install the pull-pull tubes in the fuse before putting on the sheeting. Does anyone have a picture of how they routed the tubes? Or tips on doing this, eg. where tubes should enter and exist.
Thanks |
Northernboy,
its a little confusing if its your 1st time...it is easy..did moris include the pull pull instruction sheet? sounds like they didnt....its a little seperate instruction sheet....if not let me know and i can fax you one....just follow the instructions...you cant go wrong.....let me know mike |
I scratched my head a little too, then noticed they're right on the plan. Just put your finished framework right over the plan and make a little mark where they go.
I'll tell ya something else I did too. Right behind the wing at the top and bottom of the fuse I added a doubler to the main frame. Thats where it breaks at and this little doubler doesnt add much weight. I just though I would mention it since you were at the stage before sheeting................John
| All times are GMT -8. The time now is 02:42 AM. |
