RCU Forums
-   Profile and Fun Flying Planes (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/)
-   -   Norvel 25 broken prop stud (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/868420-norvel-25-broken-prop-stud.html)
ben flyn 06-16-2003 09:25 PM
I finally got the stud out of my engine after it broke off. Where can I get another one? Do they put the prop studs in these engines because they prevent the crank from getting bent? Is this why you see so many of these engines in combat planes?
BAD ANDY 06-16-2003 09:30 PM
happened to me
while installing the first prop on mine on the pbf the stud snapped. I found hardened replacements at ACE Hardware. metric of course 1mmx1.50 I think, if remember correctly. BAD ANDY
ben flyn 06-16-2003 10:41 PM
Andy your right! I just got back from Ace with a 6mm stud and it works; thanks!!!!!
Have you ever drilled out a harden bolt?
BAD ANDY 06-16-2003 11:21 PM
way to go
Glad it helped buddy. It is quicker than trying to order one. And yes I have had to drill out hardened bolts before and you can do all the rest of them for me.. Have a good one, BAD ANDY
Tattoo 06-17-2003 12:58 AM
Yep...a lot of combat pilots fly the Norvels...and the stud breaks before more serios damage happens. I get 6mm hex head bolts, and just "bolt" the prop back on:)
ben flyn 06-17-2003 01:04 AM
Great idea Tatto! You do it all the time!
