RCU Forums
-   Profile and Fun Flying Planes (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/)
-   -   hovering is easy (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/967023-hovering-easy.html)
JAYNC 07-17-2003 04:36 PM
hovering is easy
Learning to hover isnt all that hard, just get a good computer radio and use a lot of exponetial. I have a morris hobbies gee whiz bee with a .91 saito and a 14x6 master airscrew. maybe a little overkill for the bee but boy is it ever fun.
H.Dale 07-17-2003 06:07 PM
What about Torque Rolls?
I recently put up a thread inquiring about how long it takes the average flyer to learn to hover. I am also trying to learn torque rolls. I think they are much harder. Hovering can be done into the wind fairly easy, but when you pull the plane vertical and it starts to rotate it gets a lot harder.
I notice a number of suggestions for a good plane to learn on have a short fuse which lends itself to hovering, but it not too good for torque rolls. What is a good airplane for both?
Hal
BotleRocketWar 07-17-2003 06:38 PM
hovering is easy
The longer the fuselage, the easier it's going to be to hover and torque roll. It will naturally be more stable in that attitude...
The problem is that as you get a longer fuselage, it's get's harder and harder to pull it back up once it starts to fall. It takes a bigger control surface with more throw to do the same thing.
You will see that most of the Morris Airplanes, the Flip 3D, and the UCD all have very long tail moments. That's why they are so great for hovering...It slows them down when it comes to snaps, spins, and tumbles though. There is a trade-off for EVERYTHING.
Of course those airplanes have control surfaces so dang big, it doesn't seem to make much of a difference...
Try this thread-
http://www.rcuniverse.com/showthread...133&forumid=21]
JohnVH 07-17-2003 07:01 PM
hovering is easy
Hovering is easy
:rolleyes: :stupid:
JWilliams 07-17-2003 07:33 PM
hovering is easy
JAYNC, while hovering comes easier for some than others. I still stick with the fact that it is not that easy or everybody would be doing it. It takes time to learn for the average flier. I would guess a month of heavy practice to learn hovering good. Then you would need to get the belly angle down, then TR'n, then the inverted harriers and so on. I respect the fact it may have came easy for you, it did for me too. I was hovering within a couple weeks confidently, but I have went on to more advanced hover type things and they get more and more difficult. Bottom line is that I enjoy it and it is fun. Jeff W.
tiggerinmk 07-17-2003 07:40 PM
hovering is easy
Originally posted by JohnVH
:rolleyes: :stupid:
No words required, the look said it all!! :D
Leads me to wonder, is it easier to hover an airplane or a helicopter? :p
Dave McDonald 07-17-2003 10:08 PM
Re: hovering is easy
hovering is easy
So is riding a unicycle......after you figure it out. ;)
ChuckAuger 07-17-2003 10:18 PM
hovering is easy
Helicopter, by a factor of about 10,000 in my case. After that , flying a plane is easier, but learning to hover a heli was a LOT easier to me than (still learning) hovering a plane.
Billy Hell 07-17-2003 10:19 PM
hovering is easy
Hovering might be easy for some. Hovering over the deck is never easy on the nerves the first 20 or so times.
JayNC
Do you hover down low?
wgeffon 07-17-2003 10:57 PM
hovering is easy
Jeff said it well.....
Basically, There is a LOT more to 3D than just hovering and TR'ing.
Work on Inverted harriers where the rudder seems reversed, hover low in a little wind upside down, do low waterfalls, high alpha rolls in both directions while in a rolling circle...... The list goes on and on.
Theres always more to learn.
JWilliams 07-17-2003 11:04 PM
hovering is easy
Good point Wayne, you said what I meant in better detail.
Dave, McDonald, that is also a good anology, also how did that mousse can work on your Cap an OS 160. Jeff W.
Dave McDonald 07-18-2003 01:47 AM
hovering is easy
Errrrrrrr........uhhhhhhh........it seems that I got bit by the Qhor/SPA3D bug........and came down with an acute case of Fearless Fun Flying.
The result is that the Cap and the OS 160 got pushed back down on the priority list........along with my ready-to-cover Menace.....a partially constructed PBXL.......and a slightly broken Fazer. :(
akahoverit 07-18-2003 12:15 PM
hovering is easy
I to learned to hover in a very short time, and have been doing it on and off for years now and can run a tank through it in hover, but I still have not mastered T'R's, I can do 1 but then I get sketchy, I am getting more comfortable with it though. It's hard when your hovering 5 feet off the deck knowing that if you start T'Ring you may go home and have to fix it. It's all about running lots of nitro and putting in the hrs. And watching Wayne Geffen and Jeff Williams helps to LOL.
JRozman-delete 07-18-2003 04:01 PM
I agree
Doing an inverted parachute to an inverted harrier to a inverted pop up to a TR on the deck to a gear grab at night with a mosquito buzzing in your ear and Gator and Paul casting aspersions about your manhood and your wife b!tchin to go home and a case of the red ***** and your glasses smudged is easy. :rolleyes:
ChuckAuger 07-18-2003 04:45 PM
Re: I agree
Well yeah....with smudged glasses!! :D
Texas 3D 07-18-2003 05:23 PM
Re: I agree
I feel your pain Jess. That mosquito, Paul and Gator buzzing aroud really makes it tuff. :D
TailTwister 07-18-2003 05:29 PM
hovering is easy
Hovering is easy? Well, I guess compared to some things it is.
Maybe since it is so easy, we can see your picture of you doing a tail touch to the ground.
Hovering 50 feet up, for 10 seconds, now that's easy. Now let's get nuts, and harrier, dragging the rudder on the ground, and then pull up to a waist high hover, and plop that rudder straight down into the grass. Oh yeah, that's easy too, it's the not crashing part that's tough.
http://www.my-smileys.de/nixweiss.gif
JRozman-delete 07-18-2003 05:54 PM
hovering is easy
Ulf, Chuck, LOL.
JAYNC, just funnin' at your expense. As for expo, I use very little. 20 to 30%.
I guess to some, hovering is easy, the rest of us had to burn a bunch of 3D juice to learn how to do it. :) :)
Jess
Goinstraightup 07-19-2003 01:56 PM
hovering is easy
There's definitely a point where you get the right plane (and have it set up properly) and burn enough 3D Juice where it all comes together.
It's still not easy after that, but compared to before that moment, it's 100 times easier now. The main issue is confidence. After that moment, you are confident that after a day of hovering, your plane will be in one piece. Then you can go lower (which makes hovering easier) and it all comes together even more. Then you get too cocky and crack something up - but man was it a blast!!!
My circle flying days are over.
Jeff
crashlessons 07-19-2003 02:32 PM
unicycle
"so is riding a unicycle"
The trick there is to not trying to stay on top of it, but rather work at keeping the wheel beneath your weight.
If you think of it that way, it seems easier to learn. Was for me anyway. I learned that and juggling when I was a little kid. (never know when you may decide to run off an join the circus)
Best way to learn a one-wheeler is with an old push mower.
Kinda the same with hovering. Keep the tail beneath....
Now for the next level. Inverted hover with a pusher prop!!
southern_touch9 07-19-2003 02:32 PM
hovering is easy
Hovering Easy???
Well it depends. I tried to hover for a year or two but the fact was that I didnt have the right tool for the job. I couldnt buy one of the nice 40% that hover so I had to learn on a giant stinger (with a G-62) That airplane is hard to learn hover b/c it torque rolls without you telling it to and no matter how much aileron you put into it you cant stop it. Then I switched over to the 3D planes and its MUCH easier, but to call it easy??? I dunno. I can do a tail touch but I have worked my @$$ off to be able to do it. I usually give advice to the up and rising 3D hopefuls at the field that if you want to do the hovering and stuff you have to have the right plane, servos, and engine combo. I built a modified SPAD Qhor last week and it hovers as easy as anything out there but you still got to have that stick time.
Luke 3D returns 07-19-2003 02:51 PM
hovering is easy
Another juggler on RCU apart from me!blimey.
Hovering is easy.....................compared to pissing in the corner of a round room!
I found that if there is a cross wind blowing, it can get around the wing if your hovering, and push the wing round quickly, inspite of any aileron input to counterract. This made me really scared that it would happen low down, and that i would lose it, but now i just go with it and do a t/r back to a hover. :D
CHassan 07-19-2003 03:19 PM
hovering is easy
I learned to hover on my Sig SE pretty quick. I did use G2 over the winter to practice. My third or forth flight I was hovering at 15- 20 feet. Torque rolling came fairly easy too (after the g2 training). I can't hover all day, but I can do a fair job, and I'm getting better every time I fly.
