Which butan/propane are you using and where can i get some
My Feedback: (34)
I will not be using for now the onboard gas tank and am looking for a replacent for powermax. WHERE CAN i get the 70/30 butan propane tank for starting the turbine and regulator for tank.? Can i use straight propane from camping store? Coleman??
Johnny
Johnny
Walmart or just about any sporting goods store has the propane butane mix. I have always used straight propane lots cheaper around here can buy 2 1 lb cylinders for 5 or 6 bucks and a cylinder will last for a long time. You will however need a regulated valve to lower the pressure.
