Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
 Data terminal not working >
PST Jets Direct support for PST Jets Turbines.
Old 04-28-2008 | 05:22 AM
tahfiet's Avatar
Default Data terminal not working
Hi guys!
we have a problem with the data-terminal of our J-600R. It doesn't work if we plug it into the data-port of the ECU. The turbione works just fine, so it is probably not a problem of the ECU. Any advice to solve the problem at home?
BR,
David
Old 04-28-2008 | 08:09 AM
Default RE: Data terminal not working
Hi David,
Did you check the wiring and the connector plug?
If the wirig and the connector are ok, the internal circuit may be shorted. Please contact [email protected]
Thanks, Kraivuth S.
Old 05-05-2008 | 04:45 AM
tahfiet's Avatar
Hi Kraivuth!
I tried to contact you via e-mail, but that doesn't work for me... I usually never get an answer to mail e-mails from PST!
Is it o.K. to just send in the terminal for service? How much is a new one (considering sending it from Germany to Thailand, servicing and send it back....).
Best regards,
David
Old 05-06-2008 | 10:36 AM
David,
Our email is working fine and I did reply to your email. Your server may be blocking out our mails []
Contact PST again ([email protected]) and I think that buying a new one will save you more than sending one in for repair, considering the freight, duty, and taxes.
Kraivuth S.
