PST Jets Direct support for PST Jets Turbines.
ecu ??
Old 11-06-2009 | 06:07 PM
Default ecu ??
Hey, can i use a 3000 mah 7.2v nimh for my ecu in a 1300 pst turbine, manual says to use nicad or li-po also can the temp on the ecu be changed from c degrees to f degrees
Arden
Old 11-06-2009 | 08:14 PM
Default RE: ecu ??
you can use 7.2V NiCd or NiMh. For LiPo, you can use 2 cells with 25C or higher rating.
the TEMS does not allow changing from C to F, sorry. Standard turbine operation works with degree C (both full and miniature sizes).
Regards,
Kraivuth
PST Jets
