Bad Gas SolenoidValve
Hello B777,
I noticed gas flowing into the turbine prior to the start sequence. I changed the Gas Solenoid Valve and the gas flowed properly thereafter. I need a new Solenoid Valve and wire lead. Please advise how to obtain new items. Is the old valve to be sent back to the factory? Cheers, Keith |
RE: Bad Gas SolenoidValve
Hi Keith,
You can order a new one from PST or use any good 6V solenoid valve with compatible wiring/connector. The supplied gas solenoid valve is from SMC. Regards, Kraivuth S. |
B777,
I would like to order a solinoid valve and wire lead. Just let me know how to order those items from your company. Thanks, Keith |
Anyone know where i can source one of these in the uk or know the smc part number? I have the same issue today, swapped the fuel and gas valve and it worked.
Thanks in advance p.s im using the gaspar fadec not sure if that makes any difference? |
Hi,
I got mine through PST. They suggested I look at SMC but I needed the wire pig tail as well so bought from PST. The price with postage was $126....good fast service. Keith |
HI Guys you can get Valves direct from Gasper (Xicoy) for $35 Euro
Mav |
ORIGINAL: B777 Hi Keith, You can order a new one from PST or use any good 6V solenoid valve with compatible wiring/connector. The supplied gas solenoid valve is from SMC. Regards, Kraivuth S. Thanks in advance |
