Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
MUBU II F5D Build
Old 09-03-2012, 09:51 AM
  #76
D.E.
Default RE: MUBU II F5D Build
Made a winding board. wind the carbon tow around pegs and you have custom tapered spar caps.
ID:	1797985   Click image for larger version
Old 09-08-2012, 08:26 AM
  #77
D.E.
Made some wing skins. The connecting tabs will be removed later. The layup will be 5.7 oz. spread tow dbox 1.4 oz outer glass then wood skin inside for first vacuum. The second layup will put carbon tow into spar relief area with .75 oz glass on top of all then vacuum.
Old 10-28-2012, 01:01 AM
  #78
D.English
Kind of stalled out on Mubu for the moment. I was approached by the guy that designed the wing and the saw prop from Germany and he asked if I wanted to work with him on a new design that is kind of risky but with big payoffs if it all works, I said sure!
It is a real different design that his computer models show being about 4 seconds quicker and 15 mph faster than current models, again that is if it all works. That would put it down into about 48 or 49 seconds on FAI course.
I am working on a test model that will be finished in a couple of weeks and will meet with Travis Flynn and Troy Peterson to start working out some of the systems, pretty fun stuff.
being I cant fly Q40 stuff around here and also cant afford to do both I am selling off some of my Q40 stuff, I know about the classified adds but this is kind of Q40 related only. I have,
4- DS3421 servos
1- DS3517 mg servo
1- DS368 BB servo
1- NES 3121 servo
1- NES341 servo
and 6 Q40 motor mounts
400.00 shipped in US
I will keep informed here on progress of new model and am hoping to use for US team in Austria in 2014.
Old 04-15-2013, 12:05 PM
  #79
D.E.
Well I have been working on another F5D model that is very complicated, we have flown some test planes that have had mixed success and I am feeling it may be a bit to complicated for the rigors of completing a full race of flights without a problem. I am going to continue working with it but want to try out this wing also. I have made a pod mold for a pusher set up as that is what this is designed for and have a hobbyking motor/esc set up for a speed of about 150 to 160 mph. I am laying up a light model that we hope to fly at the next Whittier EF1 race.
ID:	1872471   Click image for larger version
ID:	1872472   Click image for larger version
ID:	1872473   Click image for larger version
ID:	1872474   Click image for larger version
ID:	1872475   Click image for larger version
ID:	1872476   Click image for larger version
Old 04-16-2013, 06:32 AM
  #80
BadThumz
Dave, you do some of the most interesting modeling. I enjoy it to the max. Can't wait to see this finished.
Old 04-21-2013, 01:50 PM
  #81
D.E.
Thanks BT,
I vacuum bagged the carbon spar caps in the slotts in the wood skin then measured and cut spars and closed the molds, tomorrow is christmas if it comes out of the molds...
ID:	1874945   Click image for larger version
ID:	1874946   Click image for larger version
ID:	1874947   Click image for larger version
Old 04-22-2013, 08:00 AM
  #82
D.E.
Out of mold, 250 grams with pod should be about 650 grams ready to fly with hobbyking set up. Quality is okay, next one will be better. Now to paint some trim, will be very patriotic.
Old 04-22-2013, 12:01 PM
  #83
BadThumz
If this works out, which I expect it will, I will need one!
Old 04-22-2013, 12:38 PM
  #84
D.E.
I got further than I thought I would today, next weekend I will start to get it ready to fly... Hope to have parts machined for my other project by the time this is flying
ID:	1875274   Click image for larger version
ID:	1875275   Click image for larger version
Old 04-22-2013, 01:18 PM
  #85
daven
Awesome, looks like a boomerang!
Nice work.
Old 04-22-2013, 01:54 PM
  #86
BadThumz
Dave, beautiful.
Old 04-28-2013, 02:31 PM
  #87
D.E.
Getting ready to fly, Installing servos, loading pod with drive stuff, cutting surfaces loose and gluing pod to wing. I hope to fly next weekend unless I decide to build a folding prop mold with the 7/10 prop I have. I am afraid this will break a prop every time it lands without the ability to fold.
This pod will only be used a few times as the final F5D version will use a different motor and drive, this will let me know if it flies with cheap parts at risk.
ID:	1876878   Click image for larger version
ID:	1876879   Click image for larger version
ID:	1876880   Click image for larger version
ID:	1876881   Click image for larger version
ID:	1876882   Click image for larger version
Old 06-01-2013, 08:43 AM
  #88
D.E.
The Mubu Flew...
It actually flies really well but getting it into the air as a pusher is real tricky, It weighs 800 grams as is and needs to weigh 1000 grams minimum for the class and I think it would be a toss up to get it going at 1000 grams. I am going to go with my original idea of being a puller, I think this will make launch much better with power on and good air over surfaces at low speed.
Time to make one with full power and tractor, should be quick as I already made all the molds. Today I made some plexiglass templates to cut material.
The German/Austrian guys are going in the low 50 second range with a contest fast time of 51 seconds and that is on the same course as a F3D runs on, cant imagine if they were not limited to 1000 watts/minute.
Looks like team trials will be in San Diego on the first weekend in October, although I have no chance and could not afford to go if I made it I am going to try just to cross off of my bucket list...
ID:	1887520   Click image for larger version
Old 06-04-2013, 06:16 AM
  #89
kane
WELL DONE!!!
DK
Old 06-08-2013, 12:27 AM
  #90
D.E.
Thanks DK....
Tractor version coming along nicely. I will take some pics of wing skin layup suggested by the German designers but you will notice there is no wood skin in front of spar or in elevator/aileron area. There will be spread tow carbon on 45 for Dbox area from spar forward. The wood is also left out of aileron/elevator for spread tow to keep surface as light as possible to help prevent flutter and give some room for RDS linkage for no external linkage.... we will see.
ID:	1889820   Click image for larger version
ID:	1889821   Click image for larger version
Old 06-09-2013, 01:59 PM
  #91
D.E.
Layed up some wing skins today using spread tow carbon, next time I will buy the expensive stuff as the cheap is a pain to work with. The layup is 1.4oz glass at 90 degrees then 5.7oz spread tow at 45 degrees for the dbox and aileron/elevator surfaces. Tomorrow I will lay in the tapered spar caps using 12K tow, it will have 16 tows at center going to 3 tows at tip and then 1.4oz inner glass.
ID:	1890291   Click image for larger version
ID:	1890292   Click image for larger version
ID:	1890293   Click image for larger version
ID:	1890294   Click image for larger version
ID:	1890295   Click image for larger version
ID:	1890296   Click image for larger version
ID:	1890297   Click image for larger version
Old 06-10-2013, 09:46 AM
  #92
D.E.
This morning I put in the spar caps and inner glass
ID:	1890514   Click image for larger version
ID:	1890515   Click image for larger version
ID:	1890516   Click image for larger version
ID:	1890517   Click image for larger version
ID:	1890518   Click image for larger version
ID:	1890519   Click image for larger version
Old 06-11-2013, 05:42 AM
  #93
BadThumz
Dave, I have further respect for all the work you put into these new designs. Ken in Livermore.
Old 06-23-2013, 08:46 AM
  #94
D.E.
Tractor MUBU coming along slowly. Here is picture of RDS elevator linkage, first for me and I hope it works, also a pic of where prop drive shaft goes through spar... that is silly...isnt it?
ID:	1894357   Click image for larger version
Old 07-01-2013, 04:40 PM
  #95
D.E.
Time to work on the other secret project (will show when time) but had the prop made on 3d printer to see what it looks like before mold cut.
ID:	1896858   Click image for larger version
ID:	1896859   Click image for larger version
Old 07-14-2013, 02:20 PM
  #96
D.E.
Here is the other thing I am working on. First pic is kind of end design second and third pic is a test plane almost ready to go with cheap chinese stuff to crash. Finished model will have sleek F5D long skinny thin wing. The wing design that we are playing with now is only 6mm thick about 2/3 span
ID:	1900262   Click image for larger version
ID:	1900263   Click image for larger version
