Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Q-40 Racing
Reload this Page >
AR-6 Wing mold construction
Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Old 07-21-2012, 05:10 PM
  #51
Kevin Matney
Kevin Matney's Avatar
Default RE: AR-6 Wing mold construction
Here some pics for the top of wing.
ID:	1784289   Click image for larger version
Old 07-21-2012, 05:22 PM
  #52
Kevin Matney
Here some pics for the top of wing. part2
ID:	1784291   Click image for larger version
Old 07-25-2012, 12:11 PM
  #53
diggs_74
diggs_74's Avatar
Not being one to go back on my word, I am sorry to say I am once again attacking a FG wing mold for the AR-6. After learning that my foam core wing construction skills leave much to be desired, I figure a CNC plug and FG mold are the only solution. As Kevin posted above, he did some really top notch CNC plugs out of MDF that I will be finishing and make the mold from. This will ensure a straight and true finished product.
Because the steps used are no different than what I've previously posted, I will not bore you all with the filling, sanding, priming, sanding etc and will just show the finished product. Hopefully, without bullet holes this time
Old 07-25-2012, 12:28 PM
  #54
fizzwater2
My Feedback: (61)
Good luck with that, Lee! The bullet holes were kinda fun in a warped way, though..
Old 07-25-2012, 12:35 PM
  #55
Kevin Matney
Are we using Johnson paste wax?
And PVA this time
Old 07-25-2012, 12:42 PM
  #56
diggs_74
diggs_74's Avatar
Not sure about the Johnson's but I'll probably pick some up and try it on the stab mold.. PVA for sure though.
Old 07-25-2012, 03:51 PM
  #57
Kevin Matney
I tried every thing under the sun for wax and keep going back to it. That is for over 30 + years!!!!
Old 07-25-2012, 08:07 PM
  #58
GSJames
GSJames's Avatar
ORIGINAL: fizzwater2
Heck, I just thought he had discovered a new way to lighten the weight a bit...
Old 07-28-2012, 09:23 AM
  #59
Scorpion Racing
Scorpion Racing's Avatar
Lee, just de-molded my first Frekote mold, and all I can say is WOW! It was 10 times easier to release the plug than Partall & PVA ever were. Not to mention, it only took 1 hour to go from polishing the plugs, to laying down the surface coat for the mold. If you haven't started with the wax, I suggest you get a quart of Frekote FMS mold sealer and a quart of 770-NC release. If you want to use the wax & PVA for part production after you pull the molds, you can use the Frekote mold stripper and then apply the wax & PVA.
Just thought you might want to know!
Old 07-28-2012, 11:12 AM
  #60
Kevin Matney
I will never use Frekote any more I lost 2 mold to that stuff,NEVER MORE
Old 07-28-2012, 12:26 PM
  #61
Scorpion Racing
Well, I am sorry to hear that Kevin. I used the mold sealer, followed by the release (3 coats of each, 10 minutes apart and wiping off before it dries) and it worked flawlessly for me. I know It only has a 6 month (or less, if you don't keep it airtight and room temperature) shelf life once opened. You also have to use a catalyzed 2K paint (I used an AU automotive from Napa) for best results. I know some resins & paints have compatibility issues with certain releases, so that might have been what happened to you. []
I did some sample lay ups prior to risking my plugs, so I was sure it would work with my components. I also laid up some flat panels (identical to the mold surface) so that I can test paint/resin compatibility prior to putting it into my molds. I broke my last quickie fuselage mold by using a resin/paint combination that went thru Partall #2 wax & PVA #10. [:@]
Old 07-28-2012, 05:59 PM
  #62
Kevin Matney
Bottom of wing plug
ID:	1787134   Click image for larger version
