mvvs grrt engine
looking for any info on this engine,just ordred it for an open class formula one plane. (not for compitition just like to fly fast)props fuel anything you thing i should know.
Shawn,
I guess I'd have to help you out since no one has reply yet.
Anyhow... for the GRRT FAI .40 Pylon engine, it should be run with a pipe and there are several different size props you can use. However, depending on the plane and weight, you may have to experiement with these recommended props.
Try APC 8x6, 8x7, 8x7.3 D-1 Hub, Carbon Fiber 7.5x7-7.5 and APC 7.4x8. With these props you will know what's best for your plane. I've used mostly the 8x7 or 8x7.3 on my Quickie plane and my GRRT .40 turn over 22,000+ (which is low due to load) on the ground, but when it unloaded in the air... it's scream!
As for the fuel and plug... I used 15% nitro and McCoy #9 cold plug. Although, you can run the alcohol or 5% nitro with good result. Hope this help a little.
Sam
Sam
Hi now is this Q500 plane have a MVVS Q-500 .40 OR NElSONOR
. It cause I need alot of help with my engine. If you can help I
apree/she/ate it you could help me.
thanks . speedman
thanks . speedman
Hi Speedman,
The engine that I used with the Quickie plane is a MVVS FAI GRRT .40 with a tuned pipe (not Quickie 500 engine). It's timed for high rpm and tuned pipe use.
What kind of help do you need with your engine?
Sam
Sam
