Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Finish a Sheeted Q500 Wing
Old 09-25-2016, 03:36 PM
sahartman21
Default Finish a Sheeted Q500 Wing
The finishing epoxy was cured a few hours later.
Verify the finishing epoxy is hard before removing the peel ply. It was removed by pulling the fabric off the wing.
After removing the peel ply the edges were trimmed with a sanding block. The surface of the wing was lightly sanded with 220 grit sand paper on a block.
Two of the 4 wings are now glassed.
ID:	2182824   Click image for larger version
ID:	2182825   Click image for larger version
ID:	2182826   Click image for larger version
Old 02-12-2017, 03:18 PM
sahartman21
Today I glassed a couple more Q500 wings.
These are strong enough for 426 or 428 classes and are also legal for 424 racing.
It was relatively cold in the garage so an electric blanket was placed over the cores to speed up drying.
ID:	2200774   Click image for larger version
Old 02-28-2017, 10:38 AM
paof
paof's Avatar
thanks very much nice job
Old 03-23-2017, 09:25 AM
sahartman21
Racing season is just around the corner so it is time to finish these up.
The aileron torque rods were based upon Dubro's Heavy Duty E/Z Adjust Strip Horn Set (Cat No. 558). It was cut and bent to shape.
The grove was filled with a mixture of finishing epoxy and micro-balloons. I raised the trailing edge to level out the surface.
ID:	2206647   Click image for larger version
ID:	2206648   Click image for larger version
Old 03-23-2017, 09:29 AM
sahartman21
Ailerons were added to the other wings in the same way.
ID:	2206650   Click image for larger version
Old 03-23-2017, 04:07 PM
  #31
sahartman21
A scrapper blade was used to remove the excess micro-balloon mix from the wing.
ID:	2206704   Click image for larger version
ID:	2206705   Click image for larger version
ID:	2206706   Click image for larger version
Old 03-23-2017, 04:12 PM
  #32
sahartman21
The four wings weighed between 15.9 and 16.9 ounces each.
These are fiberglassed and are ready to prime and finish with the paint of your choice.
ID:	2206708   Click image for larger version
Old 04-08-2017, 10:05 AM
  #33
sahartman21
Some finishing epoxy was mixed and applied at the hinge line. Any excess was removed from the surface.
The purpose is to provide a protective barrier over the exposed foam.
ID:	2208869   Click image for larger version
ID:	2208870   Click image for larger version
ID:	2208871   Click image for larger version
Old 04-08-2017, 10:10 AM
  #34
sahartman21
Some surface filler was made from some spackle and water. The desired thickness is about like thin mayonnaise.
This is rubbed into the fiberglass cloth to fill in the pores.
This is set out of the way to dry.
ID:	2208873   Click image for larger version
ID:	2208874   Click image for larger version
ID:	2208875   Click image for larger version
Old 04-09-2017, 12:24 PM
  #35
sahartman21
The wings were sanded with a sanding block (150 and 220 grit paper) to remove the majority of the spackle.
The intent is to leave the fill in the pores and remove the rest.
ID:	2209021   Click image for larger version
Old 04-10-2017, 04:53 PM
  #36
sahartman21
The wind calmed down so this evening the wings were primed outside.
White KlassKote was used used as it works well with all the paints that I use. I mixed about 3 ounce per wing. This was thinned one-to-one with lacquer thinner.
Old 04-10-2017, 04:56 PM
  #37
sahartman21
No, you haven't seen a ghost.
The wings were lightly sprayed with white primer.
ID:	2209217   Click image for larger version
Old 04-14-2017, 03:24 PM
  #38
sahartman21
The wings were lightly sanded with 400 grit sandpaper used dry.
ID:	2209695   Click image for larger version
Old 04-22-2017, 09:27 AM
  #39
sahartman21
This morning the red base coat was applied to my wings.
I mixed some acrylic enamel paint that I got from TCP Global.
I added approximately 25% reducer to the mixed paint to make it suitable for spraying.
An inexpensive spray gun was purchased from Harbor Freight. It is now well used.
ID:	2210832   Click image for larger version
Old 04-22-2017, 09:29 AM
  #40
sahartman21
The wings were sprayed and placed out of the way to dry.
Old 04-27-2017, 11:49 AM
  #41
sahartman21
I wet sanded the surface of the wing to remove any dust and imperfections that were in the finish.
A cloth was used to dry the surface of the wing.
ID:	2212121   Click image for larger version
Old 04-27-2017, 11:51 AM
  #42
sahartman21
A stencil was applied to the wing and the rest was masked off.
Any area that is not masked off will likely get overspray.
ID:	2212123   Click image for larger version
Old 04-27-2017, 11:54 AM
  #43
sahartman21
I used a rattle can to spray the stripes and stencil.
Lightly spray a coat. Let it dry. Then apply more coats to cover.
ID:	2212125   Click image for larger version
ID:	2212126   Click image for larger version
Old 04-27-2017, 11:57 AM
  #44
sahartman21
A few minutes after spraying the surface is dry to the touch.
I removed the masking tape and stencil and let the paint continue to dry.
Old 05-01-2017, 10:58 AM
  #45
sahartman21
After a weekend of rain, snow, and wind Monday was much better for painting.
I mixed about 4 ounces of clear coat. It was thinned out 30% and filtered prior to spraying.
Several light coats were applied and the wing was set out of the way to dry.
ID:	2212722   Click image for larger version
ID:	2212723   Click image for larger version
Old 05-02-2017, 08:58 AM
  #46
sahartman21
The wing was very lightly wet sanded with 2000 grit wet and dry paper used wet.
I followed by buffing with polishing compound and a coat of wax.
ID:	2212860   Click image for larger version
ID:	2212861   Click image for larger version
Old 05-02-2017, 09:02 AM
  #47
sahartman21
The aileron hinge line was freed up by running a cutoff wheel across the internal fiberglass cloth.
Ailerons were later cut free and covers were added.
ID:	2212863   Click image for larger version
ID:	2212864   Click image for larger version
ID:	2212865   Click image for larger version
ID:	2212866   Click image for larger version
Old 05-02-2017, 09:10 AM
  #48
sahartman21
A small amount of lead was added to the left wing to counterbalance the weight of the engine.
I've found that this can be approximated by moving a balance line approximately 5/8" to the left of center.
Add lead and a mix of micro balloons and finishing epoxy until the wing balances at the new point.
ID:	2212872   Click image for larger version
ID:	2212873   Click image for larger version
ID:	2212874   Click image for larger version
ID:	2212876   Click image for larger version
Old 05-02-2017, 09:15 AM
  #49
sahartman21
Here is a picture of the polished model.
Engine and radio installation remain.
Old 05-07-2017, 01:55 PM
  #50
sahartman21
The Sam-Rai model was completed and is ready to fly.
I am in the process of finishing a couple as Seekers:
ID:	2213709   Click image for larger version
