Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Racing Wheels
Old 06-17-2002 | 01:50 AM
Default Racing Wheels
I just got my racing wheels from performance specialties . How do you mount them on the formed aluminum gear.
Jim Rogers
[email protected] PS
I got them with the axles
Old 06-17-2002 | 02:11 AM
Default Axles?
What I do, is drill a hole through the formed gear very slightly larger than the bolt of the axle (I use a caliper, and a number drilled bit). I then use blue loctite and put the bolt through the gear and into the wheel and nut. Tighten it snug enough to keep it tight, but loose enough for the wheel to turn. I try to keep the right wheel slightly tighter than the left to compensate for torque on take off.
This is assuming you ordered axles to go with the wheels. I don't believe Dave S. includes the axles unless you order them seperately.
