Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Vortex Metrics
Old 07-07-2004 | 12:18 PM
Default Vortex Metrics
Hi everyone,
Could any one tell me the distance from the LE (Center of the Wing) to the firewall of a Vortex.
I understand the distance from the Trailing Edge to the LE of the V-Tail is 13.75´´
In advance thank you very much.
Best Regards
Victor.
Old 07-07-2004 | 01:36 PM
Default RE: Vortex Metrics
Victor,
Unfortunately ALL the Vortex quickees are built a little different. Since the fuse is not made from a mold, each plane has a different length nose and tail moment (which is pretty minimal). I can give you the rough dimensions.....
Typical nose length (as you requested) is around: 4" minimum and 4 1/8 maximum.
The tail moment is about what you said, 13.75" to 14"....
I will also say that these dimensions are not performance related, as much as I would like to think they are. These measurements came about for balancing reasons, concerning the radio gear.
Randy Bridge
Old 07-07-2004 | 05:52 PM
Thank you very much.
Best Regards.
Victor Arreola
