i need speed
#31
WI
RE: i need speed
I figured out what Spatt was talking about.. Recently some youngsters decided they would pull something along the lines of.. Well, lets just say that I think Ed Geen is their roll model
#33
RE: i need speed
I have the blue and white one. It,s ok but I would be vary careful on landings if you do what i did. I put a bigger engine in it. A Super Tiger .40. That made it nose heavy , so Now I have to bring it in under power to keep it from staling. If you break the landing gear off don,t worry , Just take some carbon fiber and put it in the middle of the wing. Works for me.
#37
RE: i need speed
If your plane is too nose heavy... maybe try and get it balanced correctly to help it land better? move the battery back, put it back in the fuse behind the wing? or just add some lead to the tail?
#38
RE: i need speed
Thanks for the help luv to race. I have the battery as far back as it can pos. go. THe prob. is that a small plane can only weigh so much before it can,t handle any more and I believe I have gone over the limit as to the amount of weight this bird can handle.
