Doddger Pics...
1 Attachment(s)
Well, here it is.... If anyone sees anything that looks off let me know. What should these (46fx stock) turn for RPM with a 8.75x8.5??
Thanks in advance. |
RE: Doddger Pics...
looks good Lee.
A couple things. You should be able to peak that prop between 15,000 and 15,500 rpm with the O.S. FX. All you need to do to that engine is take the baffle out of the muffler. Leave the head and sleeve spacing alone, it does very little difference. I would suggest one of the following plugs in my order of preference: K&B HP, McCoy #9, K&B 1L. Keep the engine about 500 rpm off peak, with that prop, you need to keep it rich to allow it to unload in the air. Are those aileron torque rods on the bottom side of the wing? If anything else, thats interesting. Those look like alluminum wheels. If they are the wheels I'm thinking of, they are very heavy. There are some inexpensive "poker" style wheels available at www.lcsperformance.com or even better (still relatively inexpensive) pizza cutter style wheels their also. I wouldn't get to worried about making changes to this plane, for now I would just focus on trying to fly the course. If you are interested, I have Sonic 500 ARC that I've had for a few years. Not as fast as the vipers or predators, but a good plane to learn how to fly the course. Its got a ton of flights on it, and I think its survived a couple midairs. I'd sell it to you less receiver and engine for a very good price. I believe it has Hitec 225s on Elevator and Aileron (no rudder), and I can't remember whats on the throttle. I'd suggest replacing the battery, but otherwise, it should be good to go. I'll post a pic tonight if you want to see it. Dave |
RE: Doddger Pics...
ORIGINAL: diggs_74 Well, here it is.... If anyone sees anything that looks off let me know. What should these (46fx stock) turn for RPM with a 8.75x8.5?? Thanks in advance. It looks to me that you have your gear on backwards. The wheels should go under the leading edge of the wing. However, if you're flying off grass, perhaps you meant to do that? |
RE: Doddger Pics...
I believe we are flying off grass, however, I will test it both ways if the snow ever melts.
As far as the RPM goes, I ran it up at lunch and it was actually around 16K full lean. If I understood right I should richen it up to drop about 400-500 RPM. I guess I can test all that at the the field to make sure I don't have it too lean when the prop unloads. In respect to my aluminum wheels I haven't yet had the opprotunity to lighten them up yet. My dad has a milling machine and laithe:D Lee |
RE: Doddger Pics...
If your hitting 16k your in good shape.
Leave the gear on backwards for the grass, it will help you. |
RE: Doddger Pics...
1 Attachment(s)
Here is a picture of the Sonic. If your interested you can pick it up at your first race over here.
RE: Doddger Pics...
Sounds good Dave. I will probably race this one a few times and figure out what the heck I'm doing. I would like my second plane to be a little better and a little more "racey". I hate to not race this one after redoing the hole thing, that and my wife would have a cow.
Women, they just don't understand.....:) |
| All times are GMT -8. The time now is 06:33 PM. |
