Anything to do Before I put this plane together? PIC
My Feedback: (-1)
RE: Anything to do Before I put this plane together? PIC
ORIGINAL: CGCINC
Well, that's good to know because I hit one on each Elevator.
As far as cutting a slot for the hinge, I used the handle of the hinge slot tool and just pressed along the hinge slot and it made a nice indention.
I think (at least it's my theory) that the Gorilla glue is a good choice for the hinges because of the ''swell'' you get.... Seems it will put pressure against the wood and hinge to help hold it in. ???? Just my thought....
ORIGINAL: Gray Beard
CGC, if you are cutting a hinge slot and hit a rib the machine ususlly cuts a nice clean slot in the rib and the glue repairs it. Things like that happen. I have had the Dubros pull loose when using CA. That's when I got into the habit of pinning them from the bottom. I haven't had any pull loose using Gorilla glue but that may just be dumb luck??
