 Servo info needed >
Servo info needed
Servo info needed
Old 10-31-2010 | 01:57 PM
Default Servo info needed
hello does any one know of the Mg 995 Tower pro servo;s . Some one has told me that they have a problem of over throw .
In other words when you move the stick on the radio the servo will move a lot more than what the radio is signaling it to do . And it was said that the reason is because the metal gears are heavier Than the big name brand and the expensive ones . If any one uses these servos please
Any info would be a great help .
As I have these servos in my ESM P47 with an RCGF 26cc engine and I dont want to see it crash do to bad servo's
Thank you
hyflyer9 Daniel.
Old 10-31-2010 | 03:44 PM
guille2006's Avatar
Default RE: Servo info needed
Forget about those servos: DON'T USE THEM ON A PLANE!!!!!
I' bought three of them and get really dissapointed: no centering, no presicion and several "blinkings" even without input. ANother thing: if you open the case, you'll note the worrst electronic cardboarding setup ever seen. There isn't any protection against vibrations nor shocks, wire soldering is just embarrasingly bad...
Mine three are there, in a box waiting for some car or kid's toy... O don't know.
Hope it helps.
