How to set a Pull-Pull Rudder...?
VA
Hi All,
I just ordered a Somethin Extra ARF and would like to use a pull-pull rudder and elevator setup (recommended here).
How do I set this up? What hardware will I need?
Any help appreciated for this relative newbie..
Harold
Harold
I'm sure it will you've got to have faith
I used great planes 4/40 eye connectors on the servo and used 4/40 great planes metal clevis on the control horns at the rudder. You will need to pick up a pull pull system at your local hobby shop but make sure it has the control horns setup for the rudder as well.
Randy
I used great planes 4/40 eye connectors on the servo and used 4/40 great planes metal clevis on the control horns at the rudder. You will need to pick up a pull pull system at your local hobby shop but make sure it has the control horns setup for the rudder as well.Randy
