CORONA 2.4 RX/TX BINDING PROBLEMS
CA
[size=2]CORONA 2.4 TX/RX PROBLEMS: I have 4,6, and 8ch Corona rx/tx coupled to a Futaba 9C. After having bound the tx/rx the 4 and 6ch will 'lockon' immedately upon power up, however with the 8ch I have to cycle the tx and rx several times to get 'lockon'. I've noticed that moving the tx some distance away from the a/c the 'lockon' sometimes occurs immediately. I'm writing this because 7 days ago I lost an aircraft after 3 minutes of flight. I assumed it was an airborne problem. Two days later I lost another a/c right after t/o. Different 8ch rx, same tx. Instruction accompaying the equipment states it my take up to 30 seconds to aquire 'lockon'. Any thoughts or simular experiences?
My Feedback: (69)
NC
RE: CORONA 2.4 RX/TX BINDING PROBLEMS
I've had the same problem with an identical setup. I have recently switched to the FRYSKY telemetry system and my problems went away. Suggest you do the same.
Steve
Steve
