 What else do I need ? >
Old 11-17-2010 | 03:51 PM
My Feedback: (19)
Default What else do I need ?
My first GASSER..........
I have a great plane giant super sportster, 82", 5- 645mg servos and a US Engines 41cc engine. I have the radio gear. Gas conversion stuff for fuel tank....... What else do I need ? Voltage regulator ??? Optic kill switch ???
Old 11-17-2010 | 06:26 PM
ChuckW's Avatar
Default RE: What else do I need ?
Does the engine have a magneto or electronic ignition? Either way, you will need an external physical kill switch. On the Magneto equipped engine, the switch grounds the ignition and kills the spark. On an electronic ignition it disconnects the battery from the ignition box. Having a way to kill it with the radio is necessary too. On some engines you can reliably shut it off by completely closing the throttle. Having a physical servo-actuated switch to ground the magneto or an optical kill switch for electronic ignition is a good idea though.
