Tail Draggers
JP,
For most of my aircraft I prefer TD. I fly giants and there is very limited nose gear equipment available in that class. If I am flying from grass I prefer TD. If I am flying from pavement, I like to have at least one 'just for fun' knock-around bird that is a nose dragger. More relaxing on the ground and more tolerant of my cross-wind landing technique.
... but that is just me. We do this for fun and that should be the prime driver of the choices made.
Bedford
Bedford
I like both.
My current favourite model is a Birdie .40 with tricycle gear. Mind you, in 25 years' flying, this has been only the second nose-wheel that I've owned; as far as I can recall.
BUT, I've recently acquired an Astro-Hog ... a "gizzit" that arrived in tat order, but is now lovely again. This flies really nicely and is, of course, a tail-dragger. Conventional gear is more challenging, and is therefore more satisfying to use. It's generally easier to make it rugged, too.
I suppose that, on balance, conventional gear is more practical for the rough surfaces which usually masquerade as our runways... though nothing beats the practicality of simply discarding the undercarriage.
My Feedback: (-1)
I have one plane as a trike, it's the only plane I have ever built as a trike. I like it. Ground handling is really easy both on take off and landing. Other then ease of hauling the tail dragger has nothing better to offer. I have just always built TDs?? This one trike I built I did add a small servo just for the streering so I have no linkage problems.
RCU Forum Manager/Admin
My Feedback: (9)
I fly both and have no problems with either. I agree that taildraggers are simpler and have less issues than a trike gear plane. But if pushed I'd probably pick trikes as my favorite though. Don't know why but I just like the looks of a trike as it sets down in a landing. But that's just me.
Ken
Ken
My Feedback: (-1)
After reading Kens post I gave it more though, I think the only reason I don't have more trike geared planes is just because I build only planes I like and most of those are TDs. I think the reason I don't use trikes for my smaller pattern type planes is just the ease of set up on a TD?? The plane I learned to fly with was a TD so maybe I'm just stuck in a rut? When I built my Daddy Rabbit, a small pattern plane designed in 66, I was talked into building it as close to old school stock as I could force myself. That goes against my nature but I did it. It's a nice plane, handels well in the air and on the ground. I cut out a card board box to set it in for hauling. I like them both, I just seem to build TDs??
AR
The reason I asked the question is that we see posts where guys are changing trikes to tail draggers and I'm wondering why. I don't recall ever seeing a post where someone did it the other way. Like Ken, I pesonally prefer the appearance of trikes as they sit on the ground and don't really see the advantage of tail draggers other than they are easier to build. I kind of had the idea in the back of my mind that maybe some guys prefer tail draggers because they are more of a challenge to get off the ground and we enjoy a challenge. It is true that setting up that nose wheel and keeping it where it belongs can be a pain in the butt at times. I don't know, but I like both.
Banned
I live near a small local airport. On one of the cars parked at a hanger I saw a bumper sticker that said "Real Pilots Fly Taildraggers".
My experience with RC says that take off with a tail dragger is MUCH more challenging to the left thumb.
Les
Les
My Feedback: (-1)
When I was doing fun fly events and we were flying on a hard surface if someone was using a trike we knew right away who was going to win any of the ground events. If we were on a grass or rough surface we knew who was going to come in last. At my first local field you couldn't use a trike so every plane there was a TD. That may be why I have always used the TD?? Where I fly now they are great. I have my one little pattern plane and a trainer with trike. They are easy to use but I don't have any trouble keeping a TD straight, I'm pretty sure they are going to pull left so as soon as I see that I just hit a little rudder and hold it there, no stick moving. Just give it what it needs and stay there.
For me, it depends on what genre aircraft is flying.
Classics I try to keep trikes as original, with a few exceptions like the stick.
It would be strange to fly some civilian aircraft as taildraggers.
Newer models all seem to go as taildraggers. I like them just fine...
I guess I like both in proper contexts.
Brian
Brian
