McDaniels Glow Driver...Questions and Help.
I recently bought a brand newbuilt Waco Bi-plane and it has a McDaniels glow driver on the Saito FA-200R3. The guy i bought it from said it had fired up and ran through one tank of fuel. I have went through the instructions a few times just to make sure I have the system setup correctly. The LED comes on wheni power on theRx & Tx (I have the glow driver and throttle on a "Y" and into the throttle slot on Rx)but I don't get any power to the glow plugs.There is a 4xNiCd that was sold with the plane and hooked up to the glow driver. The battery pack has 5.6v when i test it with a voltmeter. Everything else seems to be hooked up correctly and tight when I trace the wires back to their respective sources.
What could I be missing? Should I try something different?I will be talking to the guy who sold this to me asap, but he has been out of town for the last week. Just trying to be proactive.
Thank you in advance!
David
David
RE: McDaniels Glow Driver...Questions and Help.
I don't know about McDaniels but I had an Expert....if the poliarty was reversed to the glow plug it would burn them out....I know I know it doesn't make sense electrictly...but if the ground wire and the power were reversed at the unit it would fry them pretty quickly....and it was reversed in the unit.....once we swapped the wires at the unit it was ok....you might want to check that
