Work shops/area's climate controlled
All model builders, are your work shops or work areas climate controlled, and if not do you have problems with wing's warping etc???
Mines climate controlled under my houses AC/Heating system, nothing special. Wings will only warp if the temperature keeps changing, but if its a fairly steady temperature, your wings should be fine.
Jason
Jason
My Feedback: (-1)
The last three shops I had/have used some kind of heat and air but it was for me, not my planes. As soon as I walked out the door my planes were/are on there own. I have had no warping but keep my planes stored in a wrack laying flat with no pressure on them.
No not climate controlled,and no warping. Warping is a sign of poor construction or design. Unless of course left on an uneven surface. If warping from the fabric streaching then the wing needed more reinforcement.
