Gas Engines & plastic clevises
My Feedback: (7)
TX
I was kind of wondering, are plastic clevises safe to use on the Throttle Lever on Gas Engines ?? I would prefer a Metal Clevis
but try to stay away from Metal to Metal Contact.
My Feedback: (7)
RE: Gas Engines & plastic clevises
http://www3.towerhobbies.com/cgi-bin...?&I=LXD905&P=0
I like these on a G10 throttle arm.. Never had a problem yet.
My Feedback: (24)
GA
I agree with using ball links but what if it won't fit. In the picture below, a ball link would hit the fuel intake nipple if used. I have not flown this yet but I have been wondering if I can get away with using a nylon clevis too.
My Feedback: (158)
ORIGINAL: Hill202
All you need to do for a ball link is drill a new hole,, 1/8-1/4" over
good luck
My Feedback: (10)
Had the same problem, I rotated the Control Arm more forward, now the nut that hold the Ball on does not collide with fuel inlet nipple.
My Feedback: (24)
GA
ORIGINAL: weezle
you can cut the excess off of your bolt with a dremel too.
My Feedback: (24)
GA
ORIGINAL: scale only 4 me
you could have always just fliped the bolt around, and/or use a button head w/nut on the outside
Dubro makes a 2-56 bolt on ball link for 4-40 rod. They work in almost any application. Nylon clevises with nylon pins on gas throttles ALWAYS break the pin off. It's only a question of when. My occupation involves the use of small gas two strokes and any pinned clevis is avoided. They fail far to often for various reasons on gas engines.
The fuel inlet nipple can generally be carefully rotated to a new position. if they happen to get broken during the process a new one can be ontained and press fit into the hole.
