Blind Nuts
My Feedback: (12)
ORIGINAL: Redmyers
The blind nuts for the engine mount are just spinning in the firewall, any suggestions on how to get them out. Turning the bolt doen't work.
My Feedback: (-1)
ORIGINAL: huck1199
Thread the bolt in the nut then tap the bolt with a tack hammer to drive out the nut.
You also can use the same holes. What I have done is just atach 4 squares of appropriate thickness new need over the hole on the back side and start over. (assuming your bolt is long enough). If not... get longer botls.. easier than rotating the mount, redrilling, etc.
Banned
ORIGINAL: huck1199
That's what I do. It doesn't take much of a tap and they come right out.
Pete
I interpretted the OPs msg differently. I thought he ment the nut had broken loose from the wood and was spinning freely as he turned the screw.
Edwin
Edwin
