BEC voltage
Old 12-11-2011 | 04:41 AM
Default BEC voltage
any one know the voltage coming out of a BEC (3cell),.,.,.,.,.,.,.,.,.,.,.,.,.,.,.thanks
Old 12-11-2011 | 06:41 AM
exeter_acres's Avatar
Default RE: BEC voltage
which ESC or BEC...
they are not all created equal.. some are adjustable
Old 12-11-2011 | 06:43 AM
the one where you use a battery for servios and rec
Old 12-11-2011 | 06:57 AM
its not adj, and its the one where you use only the battery for servos and rec
Old 12-11-2011 | 07:08 AM
which one????????
many companies make BEC's
maybe a picture?
most are going to be around 5.1 to 6v... use a volt meter and check
