Multiplex UK?
Old 08-26-2003 | 08:24 PM
Cactus.'s Avatar
Default Multiplex UK?
anyone know contact details for multiplex in the UK?
i've trashed the plastic tray on my Microjet and ned a new one, also need to know any tips for making the foam return to orginial shape, my nose is a little bent
Old 08-27-2003 | 05:24 AM
Howdy phillybaby,
Sorry about your nose! How's the model?
Try Flair Products phone 01793 721303 - if they can't help directly, they usually know the name of a man who can.
Best of luck,
Regards,
wurger
Old 08-27-2003 | 08:04 AM
Cactus.'s Avatar
after gluing the 1" of nose back on, repairing the crack in the fuz i could have flow it again. right now i've bent the nose kinda straight again, but its crushed still. dont know if/how it will return to shape totaly.
the fins are knock off using velcro, the turtle deck glued back on. the main issues is Ripmax motors arn't surpeeesed enough even tho they say they are. i need to sort out the interference with capictors on it, and maybe some foil on the wire runs too.
Thanks Wurger, will ring them soon
keep an eye on my site for what happens next
Old 08-29-2003 | 01:57 AM
Multiplex is now owned by Hitec, if that helps any.
Did you know that the foam they use can be repaired using CA? At least the foam on my Twin Star can be. I knocked off the end of the aileron and glued it back with thick CA and it worked great.
Old 08-29-2003 | 08:55 AM
Cactus.'s Avatar
the MJ is built using the stuff, i had it in a condition to fly in just 5 mins...
waiting on a couple of mails to hear about nose trays, other wise its out to the shop to get some card and make one from a mould.
anyone interesed in nose trays if i have to do that? either that or £12 for the entire plastic set
