horsepower rating on a evolution .61 nx.
My Feedback: (15)
PA
Why can't I find a horsepower rating for a evolution .61nx? No one lists it with the other specs. Can anyone help me here? I'm looking at buying one, but I want to know it has enough power.
Moderator
RE: horsepower rating on a evolution .61 nx.
I couldn't give you numbers, but it's a typical .60. If an OS, Thunder Tiger, Magnum, etc. would be enough then the Evolution will too.
HP on model engines is a weak comparison number as most are fudged from the manufacture by running too small a prop to get the rpm up than what will fly a plane. It is going to be around 2 hp. If t is a .60 size plane, it will be ok. If the plane is bigger than a 60 size one, better to get a bigger engine unless it is a floater.
