Front Gear
AR
Front Gear
Does anyone know for sure which way the coil on the front gear of a tricycle setup supposed to be installed? Is it so that the coil tightens as the wheel hits bumps or is it supposed to loosen as it hits bumps? I've seen them both ways and they both seem to work, but one way must be "correct".
RE: Front Gear
I have a couple Avistars with trike gear that I use for teaching. After a few hard landings, the front gear will be bent back at about a 30 degree angle. I have turned the gear around several times with no problems. When the gear gets bent again, I just turn it back around, I've not noticed any difference either way.
RE: Front Gear
To paraphrase a signature:"In theory, there is no difference between tighten and loosen; In practice, there is - tighten looks cooler to most."
