Help with dual battery system
MI
Need Help With Dual Switch Dual Battery Power System I could'nt figure where to put this so here it is.
Something is not right with my setup. I am running a Dual battery Dual Switch system into a airtronics 2.4 reciever. The setup is 2- 5 cell Tenergy 2000AA Nickel Metal Batteries run into 2- 5470 MPI switches with the 3 leds One battery into each switch. Run into 2 seperate channels on the reciever. I cut the loops on the back of the switches like the directions say to run them on 5 cells. When I turn one switch on it is back feeding to the other switch and lights the leads. That is one problem. But I figure that would happen. I am running 2- aileron servo's, 2-elevator servo's, 1-flap servo, 1-rudder servo. and throttle. After running for a while I checked like the directions say by moveing all flight controls at the same time and if the leds start flickering it says time to recharge. Well I did but Im only putting back 300mah back into each pack. I even checked the packs under load with a hangar nine load tester and they were in the green. The packs are new am I in need of going to an A cell to power the 7 standard size servo's. Or am I possibly having a problem with the switches feeding into each other. Because when I start with a full batteries the led's stay solid like they are suppose to. I have another plane on one of these switches and on a single 5 cell, A cells and I can run it for it seems like hours before they will start to flicker the led's. letting me know its time to recharge. It is running one less servo though but only one battery pack.
MI
RE: Help with dual battery system
I don't remember hearing any stalling or buzzing out of the ordinary. Is there a way to test a servo to make sure its not drawing also much. I might also put a 4cell A size in it to see if I get the same problem. And if I do it would let me know the switches are having a problem working on 2 different channels and back feeding.
Your set up is sound...2 batteries 2 switches into 2 ports is a parallel circuit....where voltage stays the same but available current is additive......the problem is how the LED's are wired in your switches.....I suggest you replace one switch with a switch without LED's. or replace both switches and use a voltwatch in a 3rd port of the receiver
MI
ORIGINAL: jetmech05
MI
Ok here is what I did. I changed one switch out for a no led's switch I turned on the no led switch and I still get flicker through the other. But if I turn both the led and the other switch on it is fine with both batteries. This Makes me believe I might need A size cells. But I would think I should be able to run this setup off of 1aa size 5 cell pack let alone I have 2. I will do another test and put 2 4cell A size cell packs on the setup and see what they do.
I'm not so sure that running two battery packs in parallel without some sort of isolation between the two packs is such a good idea. What if one of the cells in the battery packs should go bad? Won't that cause the other good pack to bleed voltage down? Wouldn't it be better to have one of the commercially available battery backers installed? That is what I did with my turbine and never had a problem. Even lost the primary pack and the receiver and servos continued to function. Didn't notice in flight but when I landed the health indicator LED should that there was. Saved the $7500 I had wrapped up into that one jet...
Just my 2 cents worth...
My Feedback: (29)
I agree with this. You may want to look into a Smart Fly Batt Share.
http://www.smart-fly.com/Products/BatShare/batshare.htm
My Feedback: (14)
IN
I have run the same set up you are using for years in many giant scale planes with absolutly no issues. But here is something I have just noticed.
When you use 2 separate battery systems, ie: 2 switches, 2 batteries plugged into separate receiver ports. The current in each will be half of what it would be if only using 1 switch, battery, into the battery port. You can measure this. It is one of the advantages of doing this. I ran some tests, where I used the servo function of my transmitter to cycle all the servos at the same time, and I measured both the amp draw and the voltage drop. I used digital servos. I had 2 5 cell, 2800mah NiMh battery packs. At the moment that all the servos changed dierction, the amp draw momentarily peaked at 5-6 amps, and the voltage droped to under 6 volts. It was very brief and as soon as the servos were moving, everything settled back to normal. I tried it with analog servos, and the same spike occured , but not as high. I, first though the servos were faulty, but upon checking the servo specs, it is normal. I also checked 3 different brands, and , for the digital, high tork servos, this is normal.
So, the end of all this is. I don't think anything is wrong. I think your switches are showing this momentary current peak, and that's all. Run your set up normally for awhile and check the batteries for voltage. And you can cycle them after the test. If they test to voltage and capacity, then you are OK.
ORIGINAL: speedracerntrixie
Probably just as good. It worked fine for me...
My Feedback: (29)
Steve, your analisis is spot on when everything is working as intended. My suggestion of the Batt Share is in the event that one battery fails. With this setup you have a shared power bus between the two batteries. Should one fail, the good battery will try to feed voltage to the bad one. It is possible to drain the good battery while it is feeding the bad battery and the servos. There is no way to know this in flight so one would just continue to fly. With the Batt Share, you have isolation between the two batteries and if one fails it does not affect the other.
MI
ORIGINAL: Steve Percifield
You have a parallel circuit so when you turn on the switch without the LED's you are going to see the switch with the LED's flicker. You're going from the battery to the switch without the LED's to the receiver to the switch with the LED's and see them flicker. Now when you turn the switch on with the LED's your seeing the output of both batteries...depending on the wiring of the LED's insde the switch.
In one post above there was concern that this set up could cause problems, If a cell in one battery or the other went bad. Yes it would cause an issue. But anything can fail. You have a better chance of a switch failing than lossing a cell. This set up has been used for years in many types of airplanes. Even alot of full scale runs more than 1 battery. An MD-90 runs three.
So in a nut shell in this parallel circuit. Availiable voltage remains the same, available current (amps) is additive. Doesn't mean your using all the current available. As electricity is lazy, it only gives you the minimum to get the job done.
Another way to see this is everything from both switches is the same circuit...from one switch through the receiver to the other switch is all the same circuit. All the switch does is isolate the batteries from the common circuit
Banned
My Feedback: (9)
See http://www.hangtimes.com/parallel_packs.html for information on parallel packs.
WI
You can put diodes in the circuit. Put them in between the switch and the receiver, that way you can still recharge the bats, but the diodes will prevent reverse charge from a shorted battery. Unless my understanding of basic electronics is incorrect this should word.
MI
ORIGINAL: aerofly0610
You are really over thinking this thing.....as long as the battery switches are off you can charge. As I said the possibility of a cell going bad in flight is minimal. If it really concerns you then get a batt share. Never mind soldering in a pair of diodes..
SC
I was going to use a Batshare on a new 50cc plane. What I consider to be an very highly respected rc figure said it was not needed. He mentioned that it could be a possible failure point, so to just keep it simple. I heeded his advice. 2 new batteries, 2 new switches, plugged into one receiver.
My Feedback: (29)
ORIGINAL: scflyboy
