Dx8 trainer with Dx5e
My Feedback: (34)
Question: I have a DX8 radio that I am trying to use as a master with a DX5e as a slave with an electric plane. I have the trainer cord plugged into both radios and I test the DX8 to make sure everything is working correctly and it is. I then press the trainer button and double check the DX5e to make sure it is working correctly and it is, but when I release the trainer button on the DX8 the motor will not stop, what is causing this because this does not happen until I hit the trainer button and release it. I try unpluggin the slave from the master and the motor still runs, only way to get it to stop is unplug the battery from the plane. Everything works fine until I hit and release the trainer button. ANy ideas?
