atch and cg on flying wing
My Feedback: (7)
I notice they dont tell you if you should use the fron part of the coroplastic hatch to protect the battery on ladings, some are covered and some not , which is proper , i thought of the cooling also
The instructions call out a demension of 8.5/8 in front of the nose . in other peoples photos , I see that thaey use the hatch as a CG point , which is 8 . inches from the nose , does anyone know from exsperience which is the proper CG gor the wild wing?
