Dubro Hinges
Someday I'm going to switch to the Dubro Pin Hinges. However, I can't recall any directions on what is the proper way to install them. I'm curious about what mythods, and glues are best used for this type of Hinge.
I already found this video which looks helpful. However I was wondering why He doesn't show how to do it with the covering on. And I also had some questions about the glue He uses, and why.
http://youtu.be/skD-nql1AJc
No biggie - after finishing fitment of the hinges but before gluing, cover the plane, cut the slots in the film for the hinges and then glue 'em in.
Guessin' that he just likes to do a one piece covering of the fin/rudder, stab/elevator and wing/aileron pairs.
My Feedback: (-1)
It's a demo so you can see what he is doing. How old is this vid?? Pacer quit making hinge glue a couple years ago. The hinge slotting tools he is using are old school, I haven't used mine in years. They really removed too much wood, then the slot machine came out. I still use my exacto knife and a knife with a couple of exacto saw blades in the handle to cut some slots. The slot machine really made things easier!!
The OP was asking about Hinge Pins and not flat hinges anyway. There is a jig/guide you can buy so the holes you drill are centered, it comes with two sizes of guides for large and medium hinges. Hinge pins work well of some models and not so well on others. ARFs I would not use pins in, you don't know how much wood on the LE and TE there is.
When I build a plane I make sure I glue in added wood in the area I plane on hinging with both flat and pin hinges so I have some added area to glue to. Without the Pacer glue I use Gorilla glue or epoxy. I do open up the area of the hinge center on both the LE and TE so they leave very little hinge gap, I use both a square cut and a bevel.
There isn't a lot to say about installing hinges but I have seen pages written about them?
Hey Gene - Just did a search of the Dubro catalog. Couldn't find any hinge points, just pinned hinges.
I do like your idea of stacking X-acto blades for the slot - next time. I've used a wide kerf X-acto "big handle" saw blade. Makes for a "snug but not tight" fit for the standard pinned hinges. Never used the HD pinned hinges.
My Feedback: (-1)
ORIGINAL: JohnGilmore
I do like your idea of stacking X-acto blades for the slot - next time. I've used a wide kerf X-acto ''big handle'' saw blade. Makes for a ''snug but not tight'' fit for the standard pinned hinges. Never used the HD pinned hinges.
When I can I prefer hinge pins, it is so much easier to just drill holes for the hinges. Keep in mind, I'm a builder and don't have any ARFs so I can more often then not use what I like. ARFs have limits due to design and materials used. I cut my slots before I bevel the edges too, it's easier to align them and cut the slots.
I really am lazy and slot cutting wqas always something I hated, the machine is so much easier but still not as easy as a drill!!
