Dampening Engine Mount
CA
Hi,
I want to dampen the engine mount on a piece of equipment.
It appears that placing stiff rubber between the mount and firewall should accomplish this.
I need some Suggestions on the thickness of the rubber, what to use and where to get it?
Thanks for your help,
KW_Counter
KW_Counter
Well these dubro rubber pieces seem to be about an 1/8" thick.
Not sure if this is exactly what you are looking for but hopefully I helped.
These are made for a dubro engine mount but really I think any piece of rubber roughly 1/8" thick should get the job done.
http://www3.towerhobbies.com/cgi-bin...LXD629&P=7
Jason
Jason
