 on board glow driver >
Old 09-08-2003 | 03:07 PM
Default on board glow driver
does any one know where i can get some plans to make my own on board glow driver
Old 09-08-2003 | 03:22 PM
mulligan's Avatar
Default RE: on board glow driver
Plans???
A switch, battery, and wire will do just fine. Or do you want to have it switch on and off with throttle position? If so, then I guess you're asking for an circuit design??
Old 09-08-2003 | 03:33 PM
Check this out.
[link=http://www.cliftech.com/html/optoglo.html]Optiglo II[/link]
There is an article that explains how it works and has all the information to build one. You can buy components or a complete kit.
Howard
Old 09-08-2003 | 04:54 PM
thanx for the help
Old 09-08-2003 | 07:39 PM
Optiglo is a good choice. I've built one and use it in a scale model of the Lockheed Vega. As a sidebar--Dave Platt uses a battery in a battery box and connects it to the plug. It is on for the full flight. He says that it does not effect the lifespan of the plugs and you always get a good consistent idle. Regards.
Old 09-10-2003 | 11:10 AM
Cub Man's Avatar
My Feedback: (50)
I have plans on the cub den for them.
Old 09-23-2003 | 10:05 PM
are you still looking for optiglo II info?if so i have boards and the parts to build them
Old 10-12-2003 | 07:33 PM
no1speshal's Avatar
Jcole,
Do you sell complete assembly's of the starters? I will have an open receiver slot and I would really like to have this! If you do have a complete setup, would you consider selling it to me? Let me know.
Redman
[email protected]
