power supply output .30v over. how to reduce?? PLEASE HELP.
CT
Hi everyone..
I have a Hyperion 720i charger that requires up to 15v DC input.
New power supply sold as 15v is actually 15.3v
when I hook everything up the charger says input voltage too high.
what can I do to lower the output voltage of the power supply .30v
Thanks in advance!!
HH
Thanks in advance!!
HH
RE: power supply output .30v over. how to reduce?? PLEASE HELP.
I just read through the data sheet and user manuals...the only thing I saw for the 720i was to hook up to a car battery 12V.
So there is a couple of things I'd try.
1 hook up to a 12V source and see if the unit operates on 12V
2. Look at your power supply and see if there is an output adjustment.
I can't believe that .3V makes that much of a difference, usually you'll have a 10 percent tolerance. At 15V that would be 16.5V.....
If you're feeling brave you can put resistors in the output circuit...but the by product of resistance is heat.....
CA
There should be a way to adjust the voltage.
If that doesn't work then putting a diode in series will drop the voltage .7 volt.
Make sure it can handle the current being drawn.
Good Luck,
KW_Counter
Good Luck,
KW_Counter
RI
car 12v batterys are close to 15v at full charge. a simple rectifier filter circut should reduce the output voltage.sorry i dont have schematic for you.
My Feedback: (21)
ORIGINAL: hairlesshippy
Hi everyone..
Thanks in advance!!
HH
Hi everyone..
Thanks in advance!!
HH
