DX7 Charger
DX7 Charger
Hi everyone,
I have misplaced my DX7 wall charger but do have an old Futaba charger that I'd like to use. I recognize that Spekrum/JR have a different charge polarity which is easy enough to change on the charger. That issue aside, the Futaba charger is rated at 9.6V & 70mA. I am assuming I cannot use this given that my fully charged DX7 is over 11V but I thought I'd ask the question anyway in case the 9.6V rating is nominal. If my suspicions are correct that I cannot use this charger, then what is the correct charger voltage I should look for?
Thanks!
P.S. the Futaba charger also says "charge NiCd batteries only". The voltage question aside, are NiCd and NiMh chargers interchangeable?
Thanks!
