 Airtronics Module 7SP flap setup problem? >
Old 02-19-2013 | 03:03 PM
Default Airtronics Module 7SP flap setup problem?
Hello All,
I have a tried and true reliable Module 7sp radio. This is the first time I have tried to se up flaps with it. Has anyone ever use the flaps function? I am having a bear trying to figure it out.
The manual refers to the 7p which has 3 adjustments. trim, position 1 and position 2. The 7SP has only trim and position 2.
This makes for weird behavior......in the F/E control switch position, my flaps are half down. The adjustment pots can move the flaps slightly from this position. then, the F1 position seems to let the trim adjust move it either up or down from the center. then, f2 switch allows the Flap 2 pot to trim it up or down a bit.
The problem is I can never get the flaps all the way up or down. It will only wiggle around a mid-point.
Any ideas on what to try?
thanks,
Dave
