water based epoxy?
RE: water based epoxy?
1 Post
If you are looking for an alternative to epoxy as a surface finish with or without glasscloth look for polyurethane pond/brick sealer. It is sold in the UK as G4.
It is not as strong as epoxy.
You can apply two or three coats a day.
It is less likely to give rise to allergic reactions.
Water for cleanup.
Water for cleanup.
