Will Clear Butyrate Dope Yellow?
Yes, in my experience std clear will yellow eventually over time. Brodak sells a product called" Crystal Clear" that is not supposed to yellow over time. I bought a can and sprayed it on my last model to see how it works out thru my air guns.. I'm planning on trying it out in the next few weeks over white on a plane i'm finishing right now.....Gene
Don
DBD1, I'll do that. The model i sprayed it on as a test was allready yellow, so i could only use that event to determine how it would work thru the spray guns, and i had no problems useing it. I can tell you this though, just compaireing std Buty clear in a mason jar against the Crystal clear is a big difference! The Crystal clear is just that much clearer.. I have high hopes for it, only time will tell.....Gene
