Removing Glued-on Canopy
AR
I glued a pilot figure in a plane with that stuff. Later, I dumb thumbed the plane into a violent crash that totally destyroyed the plane--except for that pilot figure. It is still glued to the cockpit floor and I cannot get it loose. That stuff is amazing.
AR
I have some double sided carpet tape that works well. It is very thin and has fibers running through it like nylon reinforced packing tape with very good holding power on both sides. I have, on occasion, used it to mount batteries or receivers and months later the battery or receiver was still very tight. I will admit, though, that when I do this, I also run a velcro strap or nylon wire tie around the component just to be sure. I also use double sided foam tape in some cases that does much the same thing but provides a bit of cushioning for the component.
Isn't Pacer similar to RC-56? The RC-56 is water soluble. I have removed canopies glued on with RC-56 by softening the joint with repeated applications of water. Soak a paper towel and lay it on the joint to allow the water time to penetrate. It may take several soaking and peeling cycles but it will eventually come off. And then you can clean all the old glue off of each surface, again, by soaking with water. Eventually it all comes off.
Dave
Dave
Goop or a similar product works well. It can be pealed off with no damage to the canopy or the fuselage. I had a rebuild thread in the crash forum showing how I did it on my CAP 232. a search in that forum should turn it up.
Ken
Ken
I've used a double edge razor blade to separate the canopy. It's actually a fairly easy job. Gluing scrap wood to one end for a handle makes it into a safer "knife". Snapping it in half lengthwise makes it better too, as there is only one cutting edge to worry about. Depends on the ductility of the steel.
FL
Can you provide a link to those washers please? They sound interesting.
FL
By the way, you can use silicone adhesive which cuts very easily and excess rubs off plastic coverings easily enough. I've used silicone to glue lots of things to covering for the sole reason that it holds well and rubs off cleanly. No solvent necessary except maybe as a final wipe to prepare for gluing something back on in the same place.
Moderator
you've got to go to this link, http://www.airborne-models.com/html/...asp?AGroupID=7
and type 'grommets' into the search field ...
here's a pic.
I LOVE those grommets btw, they're beveled, pretty simple to use and look great too.
here's a pic.
FL
