Reload this Page >
What Is Your Best Two building Rules?
Old 02-06-2014, 12:24 PM
sensei
sensei's Avatar
Default What Is Your Best Two building Rules?
My first rule is build them light. My second rule is to follow my first rule. So what is yours?
Bob
Old 02-06-2014, 12:35 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
hey Bud you should have gone fishing with that can of worms haha, First rule, build it strait. Second rule build it light. Third rule, use the appropriate materials ( including adhesives ).
Old 02-06-2014, 01:13 PM
AMA 74894
Moderator
AMA 74894's Avatar
yupper... you guys pretty much nailed all my 'cardinal' rules
Build them light.
Build them straight
I tend to take more time cutting and sanding than gluing (make the joints as perfect as possible)
and use the right materials (epoxy where required, ply where required)
one more of my own personal rules (with only a few exceptions)
build them to LAST and to be easy to maintain.
(exception as an example... if I were building an airframe specifically for competition, that airframe really doesn't need to last more than 2 seasons at most, but DOES need to be LIGHT)
Old 02-06-2014, 01:23 PM
sensei
sensei's Avatar
LOL. I will leave that one alone...
Bob
Old 02-06-2014, 03:56 PM
JohnBuckner
JohnBuckner's Avatar
My first rule, Realize it always takes at least four times longer than first estimate.
In this way you are not as likely to stall out completely at the half way point when you realize your original estimate was a fantasy
John
Old 02-06-2014, 04:01 PM
YAT-28E
YAT-28E's Avatar
#1-Make a pot of coffee
#2-Dont glue you fingers together
Old 02-06-2014, 04:12 PM
Redback
Redback's Avatar
WIng joints are not a place to save weight by going light with the epoxy!
Terry
Old 02-06-2014, 05:11 PM
JPMacG
Don't point the new CA bottle toward your face when you go to cut the little tip off.
Old 02-06-2014, 05:15 PM
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
My first 2 rules for my building session is to make sure the coffee is hot and the music is good....Good Luck, Dave
red head
Read twice , build ( As said above ) once . ENJOY !!! RED
Old 02-06-2014, 05:26 PM
Rob2160
Rob2160's Avatar
I have built more helicopters in the last 4 years than planes so these are my 2 first Heli rules.
Rule 1. Loctite every nut and bolt.
Rule 2. Check that you loctited every nut and bolt.
Old 02-06-2014, 05:40 PM
dbacque
My top 2 rules (this is getting redundant):
#1: Build it straight. If it's not straight, it's not worth flying.
#2: Build it light. Once it's straight, the lighter it is, the better it flies.
Here's a few things I do to abide by these rules:
Cut and sand every glue joint for a perfect fit before glue is applied. Cut a new part if required. Less glue = less weight (rule #2), better fit = better accuracy (rule #1).
Correct wood for each application. Light where it works, strength where required. Provides accuracy where required (rule #1), builds in lightness (rule #2).
Correct glue for each application. Use the lightest glue that is advisable for a joint but don't be afraid to use epoxy where required. Light glue = light plane (rule #2), strong joints = accurate plane (rule #1).
Careful positioning and jigging of each part before gluing. Accuracy of construction (rule #1), increases accuracy of joint to reduce glue (rule #2).
Just my 2 points and 2 cents.
Dave
Old 02-06-2014, 06:02 PM
slapshot1997
slapshot1997's Avatar
#1: Buy something that has already been built by somebody else.
#2: Set it up carefully and fly it well to avoid crashing and having to rebuild / repair it.
Old 02-06-2014, 06:50 PM
mustangman177
John
Sometimes the journey is better than the destination
Old 02-06-2014, 08:14 PM
52larry52
Rule #1....Take your time and always do the best job you can with the the materials, talent, equipment and knowledge you have available to you. Rule #2....When you run into problems, refer to rule #1
Old 02-06-2014, 08:34 PM
speedracerntrixie
My Feedback: (29)
My rule for this coming season.......build less, fly more.
Old 02-06-2014, 09:02 PM
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
Forgive me while I gibber a bit... Since I haven't built a successful airplane beyond assembling an ARF or perform repairs post stripping the covering I find that I run out of "focus" or "drive" if it can't be done quickly and easily... I'm working on a TF GS P-47 bash and I kept stalling over the last two months. The razorback conversion from WylieWarbirds.com went on pretty easily... I struggled with the Bondo... The fiberglassing was rushed as sanding is my least favorite pastime. Now I'm at the point in the bash that I've got to do the detail work... Install electronics, engine, blah, blah, blah... boring out the Robart pin hinges and getting them right...
This is the reason that I haven't bought a kit yet. Laziness is a project killer.. too many distractions. I prefer to buy my birds and fly 'em til they're no longer flyable... Eventually... Later rather than sooner I'll slow down enough and commit... I'm thinking a big ME109 w/ an inline Kolm.. that would be ****-hot
Old 02-06-2014, 09:04 PM
sensei
sensei's Avatar
Lots of good input here so far. I can't speak for anyone else but the only epoxy I use on my wood structure airframes is laminating epoxy to bond my balsa sheeting to the foam cores utilizing vacuum, otherwise everything else is bonded with thin and medium CA including engine boxes, firewalls, and landing gear blocks, there is one exception to that though, I also use a little Gorilla glue for installation of wing tubes, spar caps, and servo rails in the foam parts prior to sheeting.
Bob
Old 02-06-2014, 09:17 PM
j41captn
The responses from most of you sounds very familiar: 1. Read twice
2. Build it straight
3. Build it light
4. Sand
5. Use correct glue
6. Good coffee and music LOL
7. Have patience and a good sense of humor
8. (I do it all the time) Glue my fingers together or to the plane
My only advice is to not give up because the best part of building is when the plane flies, take very little trim and lands like you think it should. Beautiful thing
Dave
Old 02-06-2014, 10:02 PM
lawrence b
Rule #1: Build something different, it's nice to show up with something nobody else has. (Yea, you have to draw your own plans and scratch build it)
Rule#2: Build them big, the bigger they are the better they fly. (Also as I get older I can't see the small models)
ID:	1966183   Click image for larger version
ID:	1966184   Click image for larger version
ID:	1966185   Click image for larger version
Old 02-06-2014, 10:47 PM
balsa brain
Number one for me is to never fly anything I did not build from plans or of my design and two would be never ever push a build so hard that it starts feeling like a job. This is a hobby for me and will never be a way to make a living so just relax and enjoy the build.
Old 02-06-2014, 11:49 PM
MetallicaJunkie
MetallicaJunkie's Avatar
enjoy building ..drink some good beverages of your choice...check your cuts/fit twice before gluing...dont build two wing halves at a time(no i havent done it yet and some good music or an interesting show in the back ground
Old 02-06-2014, 11:51 PM
flyoz
My Feedback: (7)
flyoz's Avatar
Use plenty of 6" nails
Old 02-07-2014, 12:53 AM
SeaJay
Hey, Lawrence B,
Is that Yellow dual engine Disk aircraft based upon some experimental aircraft of the past or your own design?? I would love to show up to the field with something like that, I know that I would be the only one here with one!!
That's one interesting looking plane!!
Craig.
Old 02-07-2014, 02:09 AM
gene6029
gene6029's Avatar
Craig, since Lawrence hasn't answered yet, i'll chime in. The yellow plane is a scale model of the Vought V-173 flying pancake. I can attest to Lawrences building skills ( he is a Top Gun contender ) and all his unusual models fly extreamly well. Dont want to get off track here just want to answer your question.....Gene
