Ailreons
Ailreons
Have a Stick and the have a servo each. This has been covered before I am sure so which is best , two plug-in on receiver or one with a "Y" harness. I guess you can fine tune the throws better if independent but I am new at this and not doing any 3-D or much more than level flight. I have a spectrum Rx and Tx so point me the way guys. gphil
MI
When you use an extra channel for the second ail. servo, it can cause problems. You may have a problem with the switch for the extra channel causing that Ail to go off center if its bumped ON.
If your really up on your TX radio, it won't be a problem, but if your starting out it best to us a "Y" harness and just set them best you can.
sticks
sticks
My Feedback: (29)
sticks
sticks
An advantage using two channels is that you can adjust the travel in the transmitter for the down position of each aileron surface so there is not as much drag. Using a y-harness this has to be done mechaically by positioning the servo arms more forward. Not a huge deal but it's easier with the transmitter.
Also if you wanted to program spoilerons, flaperons, or airbrakes (each lot's of fun on Sticks !!)you would need two channels.
I would highly recommend in this situation gphil and at this stage that you start learning to utilize your new radio and use the more modern method of one channel per servo. Is it more difficult well not quite and that whole thing about dangerous if a switch is turning off is only the result of someone that does not know how to use their radio.
Also perhaps even more important is this notion that you can just make all your adjustments in the transmitter! Well that is just bogus using two channels and two servos per aileron absolutely requires the same mechanical setup (pushrods) and adjustment first before ever touching the tx adjustments. If you do not then you will endup with excessive electronic reductions and possibly excessive expotentials, resulting in loss of servo resolution around neutral and that translates to a bad flying airplane and an undeserved reputation as a bad airplane.
Is there a viable reason to us prefer to use what you call a Y with certain types of airplanes? Oh you betcha, anytime ease of airplane assembly is required using the Y menhod is an asset. This is especially important with many types of pylon racing where the wings have to removed often quickly in a rush and reassembled for tech purposes at an event. Also for instance night flyers with lots of extra plugs to be delt with, often in the dark and cold holding flashlights or cross country airplanes maybe even assembly in a rolling boat or difficult conditions on the side a road. All these airplanes an even more will benefit from eliminating that extra plug even though you may still use two airleron servos.
The choice to Y or not is depends entirely up to you as long as you remember that either method can be adjusted just as well and either method is just about as easy to set up. Not not knowing how to use the transmitter is not an excuse to base a choice on. So dude learn how to do it now on this airplane.
John
John
My Feedback: (26)
I also Prefer the one servo per channel, if for nothing else, ease of adjustment for each individual aileron.. I have never had an issue of hitting a switch, and having one of the servos doing something that wasn't expected! With most transmitters (That I know of!) , once you slave a second channel to the aileron channel, no external switch should change that, unless programmed to do so!
Craig.
Craig.
FL
I recommend plugging each servo into its own channel. It's pretty simple and if you can't figure it out someone can help you. It's definitely worth it and then you can have everything that's already mentioned.
I have a stik that tends to float on landing so I set up the ailerons with reflex (both go up) with helps the plane settle in. But as flaps it can help you land slower (but will also make a stall nastier so be aware).
My trans is a new DX-6i The receiver is one that came with it has 6 channels I think without looking. All say what they are with only one saying aileron so guess would have to use a aux space or something if utilizing two for the controls......
[QUOTE=CafeenMan;11865825
I have a stik that tends to float on landing so I set up the ailerons with reflex (both go up) with helps the plane settle in. But as flaps it can help you land slower (but will also make a stall nastier so be aware).[/QUOTE]
Indeed and cafeenMan points out one of the many things you can do with a modern radio capable of various electronic mixes. Flaps or more often flaperons are the first thing the fellows can,t wait to try, but more often than not just end up breaking the airplane. However rigging them as he described as spoilerons makes short approachs and landing a little faster airplane on short runways much easier. I have a Seniorita that I use as an aerotowed glider and the reflexing strip ailerons I added helps when she tends to overclimb the tow plane during tow.
Another fun mix that may be on your radio when using two aileron servos is called elevator to flap mix this is not the flap to elevator mix that most folks think of. That one is just to correct pitch trim when flaps are lowered for landing. However the elevator to flap mix is something entirely different and great fun to experiment with on most stick types. what this mix does and best done through a switch to allow switching off and on in flight, is provide much tighter loops both inside and outside or at much slower airspeeds that normally required. This is a fun one.
I wont even attempt a step by step for any of this as I do not do spectrum and these days use mostly Hitec with a pinch of Fuitaba.
John
John
MI
flaperons
I am opposed to using ail. for flaps.
I have done it on a couple of planes and it did not go well. For one thing when they are down, do they function well as an ail. I don't think they do . An Ail. works the best going up and you don't want as much down. Flaps need to be separate and inboard on the wing.
My Feedback: (29)
My Feedback: (-1)
Makes little sense to buy a good radio and not use the functions it provides. I use two short extensions on the RX and it's as quick as plugging into a Y. I still adjust all the controls mechanically and if I'm off a tad then sub trim makes it easy to make small adjustments as needed. Before the days of computer radios and all I had were 4 channels the Y was a great way to do things.
My Feedback: (29)
No but every once in a while my wife and I cuddle up and watch an old B/W movie. I do occasionally break out a 3 channel airplane and have fun with it lol.
That being said I see lots of guys who just don't realize how much better their airplanes would fly of the ailerons were set up correctly. Imagine how much more difficult your airplane is to fly if on landing you need an aileron input to level the wings and with that aileron you get a pitch up and slight yaw opposite of your bank. With the ailerons throws matched and correct amount of differential this does not happen. Yes it can be achieved through several hours of mechanical adjustments or you can get it close mechanically and then dial,it in with the TX in a couple min.
Hi!
"Speed" is right!
just because a radio is capable of a lot of mixes doesn´t mean the airplane benefits from it! You still have to mechanicly trim your plane to have it flying properly.
Y-cable is simple and so is mixing so pick what ever works best,but flaps is best used inboard and ailerons outboard ...used separatly.
"Speed" is right!
